StarTech.com PCI Post Diagnostics Test Card
Quicklinx: 404GWS00 Mfr#: PCIPOST
The StarTech.com PCI Post Diagnostics Card makes troubleshooting PC problems easy. Simply plug the card into a PCI slot on a malfunctioning PC, and the card reports any problems in the form of error codes on it's LED display. These codes are then cross-referenced to the enclosed error code chart to pinpoint the cause of the problem. PC technicians and system builders can save hours of troubleshooting time and prevent non-defective parts from being replaced.
You may have to refer to your motherboard manufacturer's manual for motherboard specific error diagnostic codes.
StarTech.com PCI POST PC System Diagnostics Test Card with 2 x 7 Segment LED - system diagnostic device
System diagnostic device
