StarTech.com OAM Managed Gigabit Ethernet Fiber Media Converter - MM LC 550m - 802.3ah Compliant
Quicklinx: 99FLWS00 Mfr#: ET91000LCOAM
Hurry, only 1 left in stock!
£145.83 ex VAT
£174.99 inc VAT
Express delivery Delivered on Tuesday
Convert and extend a Gigabit Ethernet connection over Multimode LC fiber with remote management capabilities. The ET91000LCOAM Managed Fiber Media Converter lets you extend a Gigabit Ethernet connection over Multimode LC fiber, with the added benefit of remote management capabilities.
Compliant with 802.3ah OAM (Operations, Administration & Management), this managed media converter incorporates an easy-to-use web interface for operation, administration and maintenance, enabling you to quickly determine the location of failing links and the fault conditions without sending service personnel to the physical location of the device.
An effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the Ethernet to fiber converter supports full Gigabit speeds at distances of up to 550m (1804ft) through the installed Multi-Mode LC SFP. The converter also features an all-steel chassis, for durability in harsh environments.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U), as well as a replaceable MSA-compliant SFP slot.
StarTech.com Multimode (MM) LC Fiber Media Converter with SFP - OAM Management - 802.3ah Compliant - Gigabit Ethernet - 550m - 850nm (ET91000LCOAM) - fibre media converter - 1GbE
Fibre media converter - RJ-45 / LC multi-mode
External
Cabling Type
1000Base-LX, 1000Base-SX, 1000Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
9.5 cm x 16 cm x 2 cm
620 g
P/N: SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Status Indicators
Port status, power
Auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3ah
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MTBF
65,000 hour(s)
FCC, RoHS
External power adapter
9.5 cm
16 cm
2 cm
620 g
60 °C
10 - 90% (non-condensing)
99FL StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £43.94
99FL StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m In Stock £169.31
99FL StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps In Stock £148.33
99FL StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £26.11
99FL StarTech.com OAM Managed Gigabit Ethernet Fiber Media Converter - MM LC 550m - 802.3ah Compliant In Stock £145.83
99FL StarTech.com Fiber Media Converter - w/ SFP In Stock £82.65
99FL StarTech.com GbE Fiber Media Converter 10km In Stock £207.57
99FL StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
99FL StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
Type: Media Converter
Stock Status: While stocks last
Stock Status: Clearance
