StarTech.com Mountable Rugged Industrial 7 Port USB Hub
Quicklinx: 6PDPWS00 Mfr#: ST7200USBM
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 7
Form Factor: DIN rail mountable
£83.28 ex VAT
£99.93 inc VAT
Add 7 USB 2.0 ports to your industrial workspace, with support for DIN rail or wall-mounted installation. This sturdy, industrial grade USB 2.0 hub can be wall mounted or installed onto a DIN rail for convenient access to its 7 female USB 2.0 ports, providing a work area, server room, or industrial environment with USB 2.0 connectivity.
With support for Hi-Speed USB 2.0 data transfer rates of up to 480 Mbps, this 7 port USB hub is backwards compatible with USB 1.1 specifications and can be powered through the host USB bus, or self powered using a three wire terminal block connector (7-24V).
StarTech.com USB 2.0 Hub - 7 Port - Mountable Rugged Industrial - Self Powered USB Hub - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x USB 2.0
DC 7 - 24 V
6.2 cm x 13.3 cm x 3.6 cm
0.5 kg
Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 2003
P/N: ITB20D3250, MSDREADU2OTG, USB2HAB10, USB2HAB15, USB2HAB30AC, USB2HAB50AC, USB2HAB6, USB2HABM1, USB2HABM6RA
Hub - 7 ports
Enclosure Type
DIN rail mountable
Subtype
USB
Ports
7 x USB 2.0
Status Indicators
Port status, power
7 x USB 2.0 Type A , 1 x USB 2.0 Type B
DC 7 - 24 V
FCC, RoHS
6.2 cm
13.3 cm
3.6 cm
0.5 kg
55 °C
9 - 95%
6PDP StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £63.72
6PDP StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £83.28
6PDP StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £99.33
6PDP StarTech.com 4 Port Portable USB 2.0 Hub In Stock £8.74
6PDP StarTech.com 4Port USB C Hub C to A USB 2.0 In Stock £20.83
6PDP StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £143.84
6PDP StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £40.29
6PDP StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £129.88
6PDP StarTech.com 4 Port USB C Hub 10Gbps In Stock £135.21
6PDP StarTech.com Industrial USB 2.0 Hub In Stock £121.00
6PDP StarTech.com Industrial USB 3.0 5Gbps Hub In Stock £89.43
6PDP StarTech.com Industrial USB 3.0 Hub In Stock £360.13
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 7
