Mobile Workstation Cart with Monitor Mount, CPU/PC Holder, Keyboard Tray, Ergonomic Height Adjustable Desktop Computer Cart, Rolling Mobile Standing Workstation on Wheels - Portable Stand-Up Cart (WKSTNCART).
Effortless Height Adjustment
The movable standing desk includes a single monitor mount that supports a VESA compatible (75x75mm/100x100mm) display up to 17.6lb (8kg), and can be adjusted (and locked) in 1.6" (4 cm) increments to any height between 50.4" (128 cm) and 63" (160 cm) from the floor using the easy-grip handle. The monitor also has a +/-30 degree tilt so each user can find their desired angle they need to work most comfortably. -
Built-In CPU Mount
The CPU holder has an adjustable width ranging from 4.8" to 8.3" (12.2cm to 21.2cm) and can easily be adjusted by hand, without the use of tools. The mount accommodates most computer towers up to 22lb (10kg), and features two safety straps to ensure it's secured, especially when moving from one location to another. -
Perfect for Any Environment
Providing users with a complete workstation solution, the portable desk cart can be used in a variety of settings, including office training rooms, warehouses and manufacturing sites, medical institutions, schools and IT departments. WKSTNCART is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Mobile Workstation Cart with Monitor Mount, CPU/PC Holder, Keyboard Tray, Ergonomic Height Adjustable Desktop Computer Cart, Rolling Mobile Standing Workstation on Wheels - Portable Stand-Up Cart cart - for LCD display / keyboard / mouse / CPU - black
- Product Type
- Cart
- 85 cm x 64.5 cm x 140 cm
- Adjustable Height
- 1.3-1.6 cm
- Tilt
- -30° to 30°
- Rotation
- -180° to 180°
- Adjustments
- Height, tilt
- 18 kg
- Recommended Use
- LCD display / keyboard / mouse / CPU
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Steel
- Black
- Wheels Qty
- 4
- Package Content
- 4 x M4x12 screws, 4 x M5x12 screws, hex key (5mm), CPU strap, column, hex key (6mm), 4 x M4x16 screws, 4 x spacers, caster wrench, M6 wrench, mouse pad, 4 x M5x16 screws, keyboard tray, CPU holder, base, 6 x M8x30 screws, 2 x M6 nuts, 4 x washers (large), 4 x casters, 4 x washers (small), column cap, 6 x M6x6 screws
- 2-year warranty
- 85 cm
- 64.5 cm
- 140 cm
- Adjustable Height
- 1.3-1.6 cm
- 18 kg
- Material
- Steel
- Black
- Package Content
AV Furniture
- Cart
- Recommended Use
- Shelf Qty
- 1
- Cable Management
- Integrated cable management
- Tilt
- -30° to 30°
- Rotation
- -180° to 180°
- Adjustments
- Height, tilt
- Max Load Weight
- 8 kg
- Wheels Qty
- 4
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 110 cm x 72.5 cm x 17.7 cm / 20.1 kg
- Limited warranty - 2 years
