StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter
Quicklinx: 9NY1WS00 Mfr#: MDP2HD4KS
£18.58 ex VAT
£22.29 inc VAT
Connect an HDMI Display to a Mini DisplayPort video source. The MDP2HD4KS Mini DisplayPort to HDMI adapter enables you to connect a mDP-equipped Ultrabook, tablet or laptop computer, such as the ThinkPadT440 series, to an HDMI display.This adapter is compatible with Mini DisplayPort 1.2 & HDMI 4K @ 30 Hz and as a result can support video resolutions up to Ultra HD (4K) as well as the accompanying digital audio up to 7.1 channel surround sound. The mDP adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3, Surface Pro 2 or Surface Book.
With support for Ultra HD (4K) the mDP to HDMI adapter ensures you can convert Mini DisplayPort to HDMI while maintaining an astonishing picture quality four times the resolution of high-definition 1080p. The adapter is also backward compatible with previous DisplayPort revisions 1.0/1.1 with support for resolutions up to 1080p.
For a hassle-free setup the Mini DisplayPort to HDMI adapter allows for plug-and-play installation without any additional software or drivers. Plus, with a small footprint and lightweight design, the adapter maximizes portability.
To ensure compatibility with any Mini DisplayPort output the mDP adapter offers an active conversion. Active video conversion is required to maintain 4K resolutions when converting Mini DisplayPort to HDMI. An active mDP adapter is also ideal for outputting 1080p resolutions by ensuring compatibility with graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity).
The Mini DisplayPort to HDMI converter is compatible with Intel Thunderbolt devices that output a DisplayPort video signal.
StarTech.com Mini DisplayPort to HDMI Audio / Video Converter - mDP 1.2 to HDMI Active Adapter for Ultrabook / Laptop - 4K @ 30Hz - Black (MDP2HD4KS) - video converter - black
Video converter
Max Resolution
4096 x 2160
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
Enclosure Colour
3-year warranty
Video converter
Max Resolution
4096 x 2160
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
Active cable (signal regeneration), HDCP
FCC, RoHS
55 g
Enclosure Colour
Limited warranty - 3 years
70 °C
10 - 85%
9NY1 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
9NY1 StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £11.67
9NY1 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
9NY1 StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.92
9NY1 StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £18.58
9NY1 StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £21.13
9NY1 StarTech.com 3ft mDP to HDMI cable - 4K In Stock £14.50
9NY1 StarTech.com Mini DisplayPort to HDMI Cable - 4K 30Hz - 3m In Stock £16.94
9NY1 StarTech.com Mini DisplayPort to HDMI Cable - 4K 30Hz - 5m In Stock £18.14
9NY1 StarTech.com Mini DisplayPort to HDMI - 4K In Stock £24.62
9NY1 StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.58
9NY1 StarTech.com DP to HDMI Adapter with HDR In Stock £25.54
9NY1 StarTech.com Mini DisplayPort to HDMI Adapter - 1080p In Stock £11.86
