Convert an m.2 NGFF solid state drive into a standard 2.5in form factor 6Gbps SSD. Vastly increase system performance by replacing your 2.5" SATA hard drive with an M.2 solid state drive, using the SAT2M2NGFF25 M.2 SSD to SATA adapter.
The M.2 to SATA adapter features an enclosed housing that adds protection to your NGFF (Next Generation Form Factor) SSD. The added protection gives you the peace of mind to confidently use your M.2 drive in applications that require an added level of durability such as hot-swap drive bays, or external SATA docking stations.
Using an M.2 SSD in place of a platter drive better utilizes the full potential of your SATA III controller, by reducing your data transfer bottleneck with file transfer speeds up to 6 Gbps - an ideal solution for further increasing the performance of a HyperDuo array.
For wide compatibility with all of the common M.2 solid state drives, the SAT2M2NGFF25 supports multiple drive heights including: 2242, 2260, 2280.
- StarTech.com M.2 (NGFF) SSD to 2.5in SATA III Adapter - Up to 6 Gbps - M.2 SSD Converter to SATA with Protective Housing (SAT2M2NGFF25) - storage controller - SATA 6Gb/s - SATA
- Storage controller - internal
- Bus Type
- SATA
- Black
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Solid state drive
- Product Material
- Aluminium / plastic
- 6.8 cm x 9.8 cm x 0.8 cm
- 50 g
- 2-year warranty
- Designed For
- P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F
- M.2
- Host Bus
- SATA
- Product Material
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 1 x M.2 Card - M.2 Card
- Connections
- 1 x SATA 6Gb/s - 22 pin Serial ATA
- Included Accessories
- Screwdriver
- Not compatible with M.2 NVMe or AHCI PCI-Express SSDs
- Mounting Kit
- Included
- FCC, RoHS
- Limited warranty - 2 years
- 6.8 cm
- 9.8 cm
- 0.8 cm
- 50 g
- 0 °C
- 50 °C
- 5 - 95%
- Designed For
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 18in SATA Serial ATA Data and Power Combo Cable | In Stock | £6.46 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.36 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.20 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.40 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.40 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.38 |
StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M | In Stock | £5.71 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.04 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £5.34 |
StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable | In Stock | £3.88 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £37.78 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.83 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £18.54 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £19.85 |
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter | In Stock | £43.44 |
StarTech.com M.2 NGFF to SATA Adapter | In Stock | £23.26 |
StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP | In Stock | £23.80 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £56.93 |
StarTech.com M.2 RAID Controller Card PCIe | In Stock | £65.07 |
StarTech.com M.2 SATA Enclosure with USB-C | In Stock | £29.06 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £23.59 |
StarTech.com U.2 2.5" NVMe SSD Adapter | In Stock | £21.56 |
StarTech.com M.2 SATA Raspberry Pi Adapter | In Stock | £20.34 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £35.38 |
StarTech.com M.2 to U.2 Adapter | In Stock | £26.42 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £152.34 |
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 | In Stock | £29.04 |
StarTech.com 18in Right Angle SATA Cable | In Stock | £4.32 |
