Convert an M.2 NGFF SSD into a 7mm high 2.5in SATA 6Gbps Open Frame SSD. Vastly increase system performance by adding the speed of an M.2 SSD (Next Generation Form Factor) in any 2.5" SATA application, with the SAT32M225 M.2 SSD to SATA adapter.
Utilize the full potential of your SATA III controller, with an M.2 SSD reducing your data transfer bottleneck with file transfer speeds up to 6 Gbps. M.2 SSDs can also save you money by reducing your power consumption over regular platter drives.
Help protect the health of your drive with an open-frame design that maximizes heat dissipation.
- StarTech.com M.2 SATA SSD to 2.5in SATA Adapter - M.2 NGFF to SATA Converter - 7mm - Open-Frame Bracket - M2 Hard Drive Adapter (SAT32M225) - storage controller - SATA 6Gb/s - SATA 6Gb/s
- Storage controller - internal
- Bus Type
- SATA 6Gb/s
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Channel Qty
- 1
- 7 cm x 10 cm x 0.7 cm
- 40 g
- 2-year warranty
- Designed For
- P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, SATDOCK5U3ER, SATERASER4, SDOCK1EU3P, SDOCK1EU3P2, SDOCK4U313, SDOCKU313, SDOCKU313E, USB312SAT3, USB31C2SAT3, USB31CSAT3CB
- Host Bus
- SATA 6Gb/s
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Channel Qty
- 1
- Processor
- No CPU
- 1 x SATA 6Gb/s - SATA power
- Connections
- 1 - M.2 Card
- Not compatible with M.2 NVMe or AHCI PCI-Express SSDs
- Mounting Kit
- Included
- FCC, RoHS
- Limited warranty - 2 years
- 7 cm
- 10 cm
- 0.7 cm
- 40 g
- -40 °C
- 85 °C
- Designed For
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 18in SATA Serial ATA Data and Power Combo Cable | In Stock | £6.44 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.34 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.16 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.40 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.38 |
StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit | In Stock | £4.38 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.36 |
StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M | In Stock | £5.67 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.02 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £5.34 |
StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable | In Stock | £4.42 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £37.78 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.83 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £18.53 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £19.62 |
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter | In Stock | £43.44 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £56.93 |
StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA | In Stock | £35.63 |
StarTech.com M.2 RAID Controller Card PCIe | In Stock | £65.07 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £23.56 |
StarTech.com 3PT M.2 SSD Card - PCIe 3.0 | In Stock | £32.12 |
StarTech.com U.2 2.5" NVMe SSD Adapter | In Stock | £21.56 |
StarTech.com M.2 SATA Raspberry Pi Adapter | In Stock | £20.34 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £35.34 |
StarTech.com M.2 to U.2 Adapter | In Stock | £26.40 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £152.39 |
StarTech.com 18in Right Angle SATA Cable | In Stock | £4.24 |
