This PCI Express based Powered USB Adapter Card adds three Powered USB (USB PlusPower) ports to any computer, through an available PCI Express Slot, and features a low profile design that is ideal for installations in a small form factor computer case. Drawing power from either the PCI Express slot or the computer power supply, the Powered USB adapter card provides up to 3A of current to each connected device, allowing for up to three Powered USB devices to be installed at a time.Plus, this PCI Powered USB Adapter Card can be connected to StarTech.com's 2 Port 12V/24V Powered USB Adapter Card (PUSBADAP), to create two additional Powered USB ports, without using an extra PCI Express slot.
- StarTech.com 3 Port LP PCI Express 12V PoweredUSB Adapter Card - USB PlusPower - USB adapter - PCIe - USB 2.0 x 3
- USB adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- Ports
- USB 2.0 x 3
- 12 cm x 6.9 cm
- 200 g
- Data Link Protocol
- USB, USB 2.0
- Data Transfer Rate
- 480 Mbps
- Processor
- 1 x NEC µPD720101GJ
- System Requirements
- Microsoft Windows 2003, Microsoft Windows 2000 / ME / XP/ Vista
- Limited lifetime warranty
- Designed For
- P/N: PUSBDYB24V06, PUSBDYB24V10, PUSBDYB24V03
- USB adapter
- Form Factor
- PCI Express x1
- Ports
- USB 2.0 x 3
- Connectivity Technology
- Wired
- USB, USB 2.0
- 480 Mbps
Processor / Memory
- Processor
- 3 x USB 2.0 - 8 pin USB PlusPower (12 V)
- Compatible Slots
- 1 x PCI Express x1 - low-profile
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 12 cm
- 6.9 cm
- 200 g
- Limited warranty - lifetime
- Designed For
- StarTech.com 24V to Hosiden+USB B Powered USB Cable
