Laptop Riser Stand Tilted and Vertical Mount Options For Ultra-thin Laptops 11" to 15". This 2 in 1 Aluminum Laptop Stand enables you to mount your laptop in two different positions depending on your application. Its aesthetic design provides function while maintaining an elegant silver look that matches your MacBook or other ultra-thin laptops. The 2 interchangeable silicone holders allow this stand to support laptops from 11" to 15" (14mm to 16mm in thickness) in an upright position, while protecting them from scratches and scuffing.
Ergonomic design
This Laptop Stand provides you with two options for mounting your laptop to suit your desktop setup. Use it as a laptop tilted stand, giving you an ergonomic tilted position for your laptop (17°); or as a vertical laptop stand, to save space and keep your workstation organized. With the included bracket, this stand provides increased stability and weight distribution to your vertically mounted laptop.
Increased Airflow
With its open frame, this Laptop Riser Stand offers increased airflow allowing your devices to stay cooler than if they were laying flat on your desk.
Port Accessibility
The Aluminum Laptop stand has been designed with an open frame design, so you can have all the ports on your laptop easily accessed to use with docking stations, and other peripherals in both mounting options.
The LTSTND2N1 is backed by a StarTech.com 5-year warranty and free lifetime technical support.
Ergonomic design
This Laptop Stand provides you with two options for mounting your laptop to suit your desktop setup. Use it as a laptop tilted stand, giving you an ergonomic tilted position for your laptop (17°); or as a vertical laptop stand, to save space and keep your workstation organized. With the included bracket, this stand provides increased stability and weight distribution to your vertically mounted laptop. -
Increased airflow
With its open frame, this Laptop Riser Stand offers increased airflow allowing your devices to stay cooler than if they were lying flat on your desk. -
Port accessibility
- StarTech.com Laptop Stand, 2-in-1 Laptop Riser Stand or Vertical Stand, Ideal for Ultrabooks & MacBook Pro/Air up to 15", Ergonomic Angled Notebook Holder for Office Desk, Silver, Aluminum - Elevated Laptop Stand - notebook stand
- Product Type
- Notebook stand
- Placing / Mounting
- Desktop
- Package Content
- Rubber covers, QSG, stability bracket, notebook riser
- Silver
- Product Material
- Aluminium
- 16.7 cm x 23.3 cm x 7.3 cm
- 540 g
- Notebook Compatibility
- 15"
- Notebook Supported Sizes
- 11" - 15" / 27.9 cm - 38.1 cm
- 5-year warranty
- Product Type
- Notebook stand
- Desktop
- Product Material
- Aluminium
- Package Content
- 16.7 cm
- 23.3 cm
- 7.3 cm
- 540 g
- Shipping Dimensions (WxDxH) / Weight
- 22 cm x 23.8 cm x 8 cm / 540 g
- 15"
- Silver
- RoHS, WEEE
- Limited warranty: - 5 years
StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio | In Stock | £39.25 |
StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio | In Stock | £35.68 |
StarTech.com 15in Laptop Privacy Screen - Magnetic - 16:10 Aspect Ratio | In Stock | £53.24 |
StarTech.com Laptop Riser Stand, Ergonomic | In Stock | £31.22 |
