Connect an HDMI equipped laptop, ultrabook, or desktop computer to your VGA display, or projector. The HD2VGAE2 HDMI to VGA adapter allows you to connect an HDMI output from your laptop, ultrabook, or desktop computer onto a VGA monitor or projector, saving the cost of upgrading to an HDMI compatible display. Intended for outputting user generated content such as presentations, and work documents, the HDMI to VGA converter can also work to increase your productivity by extending your computer's desktop on to a secondary monitor, doubling available workspace. This active HDMI to VGA adapter offers a compact and portable solution for connecting a High-Definition VGA display.
- StarTech.com 1080p 60Hz HDMI to VGA High Speed Display Adapter - Active HDMI to VGA (Male to Female) Video Converter for Laptop/PC/Monitor (HD2VGAE2) - adapter - HDMI / VGA - 24.5 cm
- Cable
- High Speed - adapter - HDMI / VGA
- Max Output Resolution
- 1920 x 1080 - 60 Hz
- Length
- 24.5 cm
- Black
- Connector
- HDMI - male (input)
- Connector (Second End)
- HD-15 (VGA) - female (output)
- 1080p support, active adapter
- 3-year warranty
- Designed For
- P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, SV211HDUC, SV221HUC4K
- Cable Type
- High Speed - adapter 1080p support, active
- Interface Supported
- HDMI / VGA
- Jacket Material
- Plastic
- Length
- 24.5 cm
- Black
Adapters & Converters
- 1920 x 1080
- Refresh Rate
- 60 Hz
- Connector
- 19 pin HDMI Type A - male (input)
- 15 pin HD D-Sub (HD-15) - female (output)
- Plug and Play, FCC, RoHS, WEEE, REACH, RCM
- 4 cm
- 1.5 cm
- 35.3 g
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 48 g
- Limited warranty - 3 years
- Designed For
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £25.84 |
StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 | In Stock | £27.54 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook | In Stock | £16.49 |
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops | In Stock | £14.76 |
StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p | In Stock | £43.92 |
StarTech.com 10ft HDMI to VGA adapter cable | In Stock | £41.26 |
StarTech.com 3ft HDMI to VGA adapter cable | In Stock | £18.04 |
StarTech.com 6ft HDMI to VGA adapter cable | In Stock | £20.64 |
StarTech.com HDMI to VGA Adapter w/ Audio | In Stock | £13.69 |
