Scale your Power over Ethernet connection by 100m, or daisy chain up to four extenders for longer distance. This Gigabit PoE+ extender spans your Power over Ethernet (PoE) device over longer distances, letting you double the 100m limitations of a traditional PoE infrastructure.
Now you can connect your Gigabit PoE device up to a maximum of 200m away, so it's easy to install a remote IP camera or access point. Plus the extender can be daisy-chained for more scalability.
Need more distance? This convenient PoE+ repeater maximizes range and flexibility by extending your PoE connection by an extra 100m (330ft), while providing 24-watt power output to compatible devices.
Simply connect the extender to your power sourcing equipment (PSE) and your PoE-powered device (PD) and you're all set. The extender is compliant with the 802.3at/af standard, so it will work with existing PSE, such as a StarTech.com POEINJ1G PoE+ injector (POEINJ1G) or IES81000POE PoE+ switch (IES81000POE).
Still need more distance? If an extra 100m isn't enough, this full-featured PoE extender offers daisy chain capability.
You can easily connect four extenders together, letting you install your PoE+ PD up to 500m (1640ft) away. It's perfect for business, education, and retail environments (output wattage is dependent on the number of daisy-chained extenders used).
Get up and running quickly. This Gigabit PoE+ extender can be positioned right where you need it, with a wall-mountable design that requires no external power adapter.
You can enjoy reliable performance with little worry of downtime or failure, the extender features a rugged metal housing with built-in ESD and surge protection.
Unrestricted PoE+ range and convenience
Need more distance? This convenient PoE+ repeater maximizes range and flexibility by extending your PoE connection by an extra 100m (330ft), while providing 24-watt power output to compatible devices. Simply connect the extender to your power sourcing equipment (PSE) and your PoE-powered device (PD) and you're all set. -
Daisy chain for longer distance and flexibility
Still need more distance? If an extra 100m isn't enough, this full-featured PoE extender offers daisy chain capability. You can easily connect four extenders together, letting you install your PoE+ PD up to 500m (1640ft) away. It's perfect for business, education, and retail environments (output wattage is dependent on the number of daisy-chained extenders used). -
Convenient installation options and durable construction
Get up and running quickly. This Gigabit PoE+ extender can be positioned right where you need it, with a wall-mountable design that requires no external power adapter. You can enjoy reliable performance with little worry of downtime or failure, the extender features a rugged metal housing with built-in ESD and surge protection.
- StarTech.com 1 Port Gigabit PoE+ Extender 802.3at & 802.3af - 100m (330ft) - Power over Ethernet Extender - PoE Repeater Network Extender (POEEXT1GAT) - repeater - 10Mb LAN, 100Mb LAN, 1GbE
- Repeater
- Form Factor
- External
- Cabling Type
- 10Base-T, 100Base-TX, 1000Base-T
- Data Link Protocol
- Max Transfer Distance
- 100 m
- Power Over Ethernet (PoE)
- PoE+
- 9.4 cm x 7 cm x 2.6 cm
- 197 g
- 2-year warranty
- Designed For
- P/N: ST12MHDLANU
- Repeater
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- Cabling Type
- 100 m
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, 2KV ESD Protector
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- 1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ input) - RJ-45 , 1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ output) - RJ-45
- MTBF
- 50,000 hours
- EN 61000-4-2, EN 61000-4-5, FCC, RoHS
- PoE+
- 3.2 Watt
- 9.4 cm
- 7 cm
- 2.6 cm
- 197 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
- Designed For
- P/N: ST12MHDLANU
StarTech.com 100 ft Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £36.47 |
StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £36.45 |
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £207.51 |
StarTech.com 4 Port Gigabit PoE+ Injector | In Stock | £120.53 |
StarTech.com Gigabit PoE+ Extender - 100m | In Stock | £95.79 |
