StarTech.com HDMI to ExpressCard HD Video Capture Card Adapter 1080p
Quicklinx: 89CNWS00 Mfr#: ECHDCAP
Capture and convert the audio/video from an HDMI source, through a 34mm ExpressCard slot. The ECHDCAP ExpressCard Video Capture Card for HDMI (1080p) lets you capture high-definition video and audio from an HDMI source to your laptop computer through an ExpressCard expansion slot.
Support for full 1080p video input, as well as HDMI audio makes this HD capture card the perfect solution for creating digital copies of your videos for editing and compiling, or for simply recording video to your laptop.
This ExpressCard-based capture card supports NTSC and PAL systems, and includes an easy to use video capture software suite that enables you to record video or take still screenshots and save them to your laptop/notebook computer.
The laptop capture card features a flushmount ExpressCard design that sits flush with the sides of the laptop, creating a seamless add-on that can be left installed, even while on the move.
StarTech.com HDMI to ExpressCard HD Video Capture Card Adapter 1080p - video capture adapter - ExpressCard
Video capture adapter
Interface Type
ExpressCard
3.4 cm x 7.5 cm x 0.6 cm
30 g
Video Input
HDMI
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Analogue Video Format
NTSC, PAL, PAL-M, PAL 60
Digital Video Format
MPEG-4, H.264
Digital Video Capture Resolution
1280 x 720, 1280 x 960, 1024 x 768, 1280 x 1024, 800 x 600, 1920 x 1080, 1440 x 900
Microsoft Windows Vista / XP / 7, Windows 10 (32/64 bits)
Interface Type
ExpressCard
3.4 cm
7.5 cm
0.6 cm
30 g
Video
Interface Type
HDMI
Video Modes
MPEG-4, H.264
1 x audio / video - HDMI output - 19 pin HDMI Type A
Compatible Slots
1 x ExpressCard
FCC, RoHS
System Requirements Details
Core i5 RAM 512 MB
70 °C
