Build a RAID array with two mSATA SSDs that can be installed into a single 2.5in SATA bay. Vastly increase system performance by adding a dual mSATA SSD RAID array into any 2.5" SATA HDD application with the 25SAT22MSAT mSATA to SATA adapter.
Utilize the full potential of your SATA III controller, with mSATA SSDs reducing your Data transfer bottleneck with file transfer speeds up to 6 Gbps. mSATA SSDs also save you money by reducing your power consumption over regular platter drives.
You can achieve greater SSD capacity, or data redundancy with the Dual SSD controller supporting multiple RAID modes (RAID 0, 1, BIG). The SSD adapter also supports non-RAID operation (JBOD) when paired with a port-multiplying SATA controller, so both drives can be used independent of one another.
Help protect the health of your drive with an open-frame design ensuring maximum heat dissipation.
- StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter - 2x mSATA SSD to 2.5in SATA Adapter with RAID and 7mm Open Frame Housing (25SAT22MSAT) - storage controller - mSATA - SATA 6Gb/s
- Storage controller - internal
- Bus Type
- SATA 6Gb/s
- Interface
- mSATA
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Channel Qty
- 2
- RAID Level
- RAID 0, RAID 1, JBOD, BIG
- 7 cm x 10 cm x 0.7 cm
- 40 g
- 2-year warranty
- Designed For
- P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F
- Host Bus
- SATA 6Gb/s
Storage Controller
- Interface
- mSATA
- 6 Gbit/s
- Supported Devices
- Channel Qty
- 2
- RAID Level
- 2 x - mSATA
- Connections
- 1 x SATA 6Gb/s - 15 pin Serial ATA power
- Mounting Kit
- Included
- FCC, RoHS
- Limited warranty - 2 years
- 7 cm
- 10 cm
- 0.7 cm
- 40 g
- -40 °C
- 85 °C
- Designed For
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 18in SATA Serial ATA Data and Power Combo Cable | In Stock | £6.44 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.34 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.16 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.40 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.38 |
StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit | In Stock | £4.38 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.36 |
StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M | In Stock | £5.67 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.02 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £5.34 |
StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable | In Stock | £4.42 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £37.78 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.83 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £18.53 |
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter | In Stock | £43.44 |
StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA | In Stock | £35.63 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £23.56 |
StarTech.com M.2 to U.2 Adapter | In Stock | £26.40 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £152.39 |
StarTech.com 18in Right Angle SATA Cable | In Stock | £4.24 |
