StarTech.com Dual Monitor Stand - Articulating - For Monitors up to 32"
Quicklinx: FB6JWS00 Mfr#: ARMDUALSS
Accessory Type: Stand
£150.16 ex VAT
£180.19 inc VAT
Customize your workstation, and free up space, with this dual-monitor stand. Mount two monitors on the dual articulating monitor arms, and adjust your displays for optimum viewing with a wide range of motion. The free-standing base gives you flexibility in placing your setup within your workspace.
Work more efficiently with a dual-monitor setup. The horizontal dual-monitor stand lets you mount two VESA mount (75x75, 100x100 mm) monitors, up to 32", with a maximum weight capacity of up to 17.6 lb./8 kg per display.
Mounting your displays on a dual-monitor stand above the desk surface enables you to adjust your display height, position and viewing angles for an ergonomic workspace. The swiveling arms provide maximum viewing flexibility, letting you work in comfort.
It's easy to customize your setup, placing your monitors at the ideal height. Simply adjust the display height along the 16.7" (42.4 cm) pole. You can align your monitors perfectly with the micro-adjustment feature.
Extend the dual articulating arms up to 18.4" (46.8 cm) to position your monitors in the ideal position. Tilt your monitors +90/-40 degrees and swivel +90/-90 degrees for ideal viewing. Rotate your displays for portrait or landscape viewing.
Neatly route your cables, keeping them organized and out of view, with the cable-management channels.
StarTech.com Dual Monitor Stand, Ergonomic Desktop Monitor Stand for up to 32" VESA Displays, Free-Standing Articulating Universal Computer Monitor Mount, Adjustable Height, Silver - Easy & Quick Assembly stand - for 2 monitors - black, silver
Stand - desktop
92.6 cm x 11.6 cm x 55 cm
Tilt
-40° to 90°
Pan
-90° to 90°
Rotation
-180° to 180°
Adjustments
4.8 kg
Recommended Use
2 monitors
Recommended Display Size
32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
16 kg
Material
Plastic, aluminium, steel
Black, silver
5-year warranty
92.6 cm
11.6 cm
55 cm
4.8 kg
Material
Black, silver
AV Furniture
Stand
Recommended Use
2 monitors
Placing / Mounting
Desktop
Cable Management
Integrated cable management
32"
Tilt
-40° to 90°
Pan
-90° to 90°
Rotation
-180° to 180°
Adjustments
Max Load Weight
16 kg
Assembly Required
Dimensions & Weight Details
55.7 cm x 31.2 cm x 10.5 cm / 5.6 kg
Limited warranty - 5 years
FB6J StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit In Stock £95.40
FB6J StarTech.com Dual Monitor Stand In Stock £91.00
FB6J StarTech.com Vertical Dual Monitor Stand In Stock £90.68
FB6J StarTech.com Thin Client Mount - VESA In Stock £26.25
FB6J StarTech.com Under Desk Keyboard Tray In Stock £64.84
FB6J StarTech.com Vertical Dual Monitor Stand In Stock £117.07
FB6J StarTech.com Dual-Monitor Stand - Horizontal - For up to 24" Monitors - S In Stock £83.12
FB6J StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.65
FB6J StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.93
FB6J StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.94
FB6J StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £8.76
