StarTech.com Dual Monitor Mount - Stackable
Quicklinx: C19XWS00 Mfr#: ARMDUAL30
Accessory Type: Mount
£221.81 ex VAT
£266.17 inc VAT
Save space and work in comfort by mounting two displays with full-motion positioning. The ARMDUAL30 Dual-Monitor Arm lets you customize your workspace like never before. Increase your comfort and productivity with a dual monitor setup, side-by-side or stacked. The full-motion arms with articulation and spring-assisted height adjustment let you position your monitor and viewing angle anytime, and easily switch from landscape to portrait. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Create a more ergonomic workspace that matches your exact needs, while freeing up valuable space on your desk or table. The interchangeable arms with quick-connect assembly let you design a dual-monitor setup to suit your specific workstation.
In a side-by-side setup, the dual-monitor mount supports two monitors from 12" to 30". It's ideal for numerous uses in the business or home office including graphic design, gaming, photo editing and many others.
In a stacked setup, the dual-monitor mount supports two monitors, from 12" to 24". A vertical setup makes comparison easy in many applications including financial analysis, web design, reviewing spreadsheets and many others. Please note: To support two stacked 24" monitors, the height of each monitor (including the bezel around the display) cannot exceed 14" (35 cm).
The desk-mount monitor arms offer a full range of motion on several axes, letting you tilt, pan and rotate to adjust your viewing angle any time to suit your changing needs. To view longer pages or blocks of code without scrolling, the arms also support landscape-to-portrait display rotation for each monitor.
Raising or lowering your monitors is effortless, with the spring-assisted height adjustment. You can adjust the tension to your own preference.
With its heavy-duty construction, the ARMDUAL30 securely holds two monitors using a standard VESA mount. The dual-monitor mount has a weight capacity of 9 kg (19.8 lb.) per arm.
The snap-and-release design makes the dual-monitor arm mount easy to assemble and customize. For installation flexibility, the included mounting hardware lets you either clamp the monitor mount to the side of your desk or table, or attach it through a grommet hole. The arm mount also features integrated cable management channels that help to keep cables neatly tucked away.
StarTech.com Desk Mount Dual Monitor Arm - Full Motion Articulating Arms - Premium Dual Monitor Stand - For up to 30" (19.8lb/9kg) VESA Mount Monitors - Tool-less Assembly - Steel & Aluminum mounting kit - full-motion - for LCD display - black, silver
Mounting kit (full-motion)
Mounting Components
Desk mount, grommet clamp
61.8 cm x 47.6 cm x 45.1 cm
Tilt
105°
Rotation
360°
Swivel
360°
Adjustments
Pan, tilt
6.3 kg
Recommended Use
LCD display
Recommended Display Size
30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
Material
Plastic, aluminium, steel
Black, silver
Package Content
2 x M6 allen key, 2 x M3 allen key, 2 x spring arm, 2 x swivel arm, 2 x VESA monitor mount, 8 x thumb screws
P/N: ACCSMNT, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, PXT101YUK, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
61.8 cm
47.6 cm
45.1 cm
6.3 kg
Material
Black, silver
Package Content
AV Furniture
Mounting kit
Mounting Components
Design
Full-motion
Recommended Use
LCD display
Cable Management
Integrated cable management
30"
Tilt
105°
Rotation
360°
Swivel
360°
Adjustments
Pan, tilt
Max Load Weight
9 kg
Adjustable Feet
C19X StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI In Stock £68.47
C19X StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio In Stock £65.61
C19X StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £47.08
C19X StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £141.52
C19X StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £86.53
C19X StarTech.com Sit-to-Stand Workstation In Stock £243.11
C19X StarTech.com Monitor Mount - USB Passthrough In Stock £164.60
C19X StarTech.com Dual Monitor Mount - Stackable In Stock £221.81
C19X StarTech.com Dual Monitor Stand In Stock £83.12
C19X StarTech.com Desk Mount Quad Monitor Arm In Stock £178.72
C19X StarTech.com Vertical Dual Monitor Mount In Stock £70.27
C19X StarTech.com Dual 4K Docking Station, Mac & Windows - USB-A & USB-C Dock, Dual 4K60 DP & HDMI In Stock £134.78
C19X StarTech.com Thin Client Mount - VESA In Stock £23.19
C19X StarTech.com Under Desk Keyboard Tray In Stock £53.93
C19X StarTech.com USB-C Multiport Adapter Docking Station In Stock £124.67
C19X StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors In Stock £195.19
C19X StarTech.com Desk Mount Dual Monitor Arm - Crossbar In Stock £100.16
C19X StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating In Stock £99.84
C19X StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm In Stock £164.68
C19X StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.60
C19X StarTech.com Triple Monitor Desk Mount In Stock £180.66
C19X StarTech.com Triple Monitor Desk Mount In Stock £171.54
C19X StarTech.com Crossbar Dual Monitor Stand In Stock £90.08
