This USB-C docking station is ideal for use in large organizations to meet widespread office productivity requirements and compatibility with all USB-C and Thunderbolt 3 laptops. The USB-C dock features support for Dual HDMI monitors, 60W Power Delivery 3.0, fast-charge, and both USB-C and USB-A peripheral ports.
The USB-C docking station adds dual HDMI monitors support to your workstation, with full high definitions resolutions of 1920x1080 or 1920x1200 at 60Hz. With more screen space, you can access multiple applications and reference material on one display while composing on the other.
The USB-A and USB-C charge ports can charge your smartphone, tablet or other USB peripherals whether you're working or away from your desk, and even if you disconnect your laptop.
Using a single cable, the dock powers and charges your laptop as you work with 60W PD for faster charging, using the 90W power adapter.
With a smaller size and extended length 3.3' (1 meter) host cable, this USB-C dock fits easily into a workspace environment. Even where desk space is limited, this dock can be mounted to the wall, monitor or underneath the desk with StarTech.com mounting brackets (SSPMSUDWM & SSPMSVESA). These mounting brackets are specifically designed for the docks and hubs to give you the customized setup you need.
Connect your devices with four USB 3.1 ports: 1x USB[CC2] -C and 3x USB-A. Fast-charge your USB-C or USB-A smartphone. The dock provides a GbE port (Wake-on-LAN) and a 3.5 mm 4-position headset audio jack. It also includes a security lock slot (K-slot) to protect against theft.
- StarTech.com USB-C Dock, Dual Monitor 1080p HDMI Laptop Docking Station, 60W Power Delivery, 1x USB-C, 3x USB-A, Ethernet, Dual HDMI Video Display USB 3.1 Gen 1 Type-C Dock, Mac & Windows - 60W PD With Charging (DK30CHHPDUK) - docking station - USB-C 3.1 - 2 x HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C 3.1
- Video Interfaces
- 2 x HDMI
- 8 cm x 15.5 cm x 2.5 cm
- 300 g
- Black, space grey
- Localisation
- United Kingdom
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 120/230 V 90 Watt Power Provided
- 3-year warranty
- Product Type
- Docking station
- 8 cm
- 15.5 cm
- 2.5 cm
- 300 g
- Enclosure Colour
- Black, space grey
- Localisation
- United Kingdom
Video
- Max Resolution Details
- 1920 x 1200 - 60 Hz , 1920 x 1080 - 60 Hz
- Data Link Protocol
- 2 x audio / video - 19 pin HDMI Type A , 1 x USB-C / Thunderbolt 3 with Power Delivery - 24 pin USB-C , 1 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - mini-phone 3.5 mm 4-pole
- Cables Included
- 1 x USB-C cable - external - 1 m
- Security lock slot (cable lock sold separately), dual monitor support, 60W power delivery
- Security Slot Type
- Kensington security slot
- RoHS, REACH, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V
- Power Provided
- 90 Watt
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10, Google Chrome OS 55 or later, Apple macOS 10.12 - 10.14
- Limited warranty - 3 years
- Shipping Width
- 23.1 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 8.2 cm
- Shipping Weight
- 1.028 kg
- 0 °C
- 50 °C
