Connect a DisplayPort-equipped PC or Mac to an HDMI, VGA, or DVI Display. The DP2VGDVHD DisplayPort to VGA, DVI or HDMI converter offers a compact 3-in-1 solution for connecting your DP-equipped desktop, laptop or Ultrabook computer to a VGA, DVI, or HDMI display.
Compatible with almost any display, television or projector, this versatile converter provides the ideal plug-and-play solution for travel or BYOD (Bring Your Own Device) applications around the office. With three of the most common interfaces to choose from, the converter equips you to walk into any boardroom ready to connect to an available display device, even if you don't know what connection ports will be available.
For seamless connections from your DisplayPort-equipped computer, the converter supports video resolutions up to 1920x1200/1080p, so you can convert a DisplayPort video source to VGA, HDMI, or DVI without sacrificing video quality.
The DisplayPort converter offers a small footprint and lightweight design that makes it easy to keep on hand without it taking up too much space in your laptop bag.
- StarTech.com 3 in 1 DisplayPort Multi Video Adapter Converter - 1080p DP Laptop to HDMI VGA or DVI Monitor or Projector Display (DP2VGDVHD) - adapter - DisplayPort / HDMI / DVI / VGA - 26.6 m
- Cable
- Adapter - DisplayPort / HDMI / DVI / VGA
- Max Output Resolution
- 1920 x 1200
- Length
- 26.6 m
- Black
- Connectors
- DisplayPort - male
- Connectors (Second End)
- HDMI - female , HD-15 (VGA) - female , DVI-D - female
- DisplayPort 1.2
- Active cable, 1920 x 1200 (WUXGA) support
- 3-year warranty
- Cable Type
- Adapter active, 1920 x 1200 (WUXGA) support
- Interface Supported
- DisplayPort 1.2
- Length
- 26.6 m
- 7.1 channel Surround Sound
- Black
Adapters & Converters
- 1920 x 1200
- Connectors
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - female , 15 pin HD D-Sub (HD-15) - female , 24+1 pin digital DVI - female
- Plug and Play, FCC, RoHS
- 4.5 cm
- 2 cm
- 65 g
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.7 cm
- Shipping Weight
- 73 g
- Limited warranty - 3 years
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £13.65 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.91 |
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter | In Stock | £22.89 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White | In Stock | £10.59 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.38 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.92 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £25.48 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £16.29 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black | In Stock | £35.35 |
StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI | In Stock | £23.91 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £19.89 |
StarTech.com DP to HDMI or VGA Converter | In Stock | £18.50 |
StarTech.com DisplayPort to HDMI - 4K 60Hz | In Stock | £23.58 |
StarTech.com USB-C Multiport Video Adapter 4-in-1 - 95W Power Delivery - Space Gray - 4K 60Hz | In Stock | £64.19 |
