Connect your 4K HDMI display to a DP video source using this compact, passive adapter. This DisplayPort to HDMI adapter supports 4K video resolution, enabling you to connect DisplayPort devices, such as an Ultrabook or desktop computer, to a 4K HDMI display or projector.
You will be amazed at how this adapter flawlessly manages your graphics-intensive content. With support for resolutions up to 4K - four times the resolution of high-definition 1080p - its lossless performance makes the adapter the ideal solution for high-resource applications such as graphic design, CAD & CAM design, or health care imaging (MRI, radiology diagnostics, etc.).
Plus, the 4K adapter supports 1080p displays, which makes it a great accessory for home, office or other workspace applications.
This DP to HDMI adapter is extremely portable, with a lightweight, small-footprint design. It's the perfect accessory to carry with your Ultrabook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes the adapter ideal for BYOD (Bring Your Own Device) applications at the office, and enables you to arrive prepared when you're presenting to a potential client, teaching off-site, or traveling to meet with a customer.
Astonishing 4K picture quality
You will be amazed at how this adapter flawlessly manages your graphics-intensive content. With support for resolutions up to 4K - four times the resolution of high-definition 1080p - its lossless performance makes the adapter the ideal solution for high-resource applications such as graphic design, CAD & CAM design, or health care imaging (MRI, radiology diagnostics, etc.). Plus, the 4K adapter supports 1080p displays, which makes it a great accessory for home, office or other workspace applications. -
Arrive prepared, wherever you go
This DP to HDMI adapter is extremely portable, with a lightweight, small-footprint design. It's the perfect accessory to carry with your Ultrabook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes the adapter ideal for BYOD (Bring Your Own Device) applications at the office, and enables you to arrive prepared when you're presenting to a potential client, teaching off-site, or traveling to meet with a customer. The DP2HD4KADAP is backed by a 3-year StarTech.com warranty and free lifetime technical support.
- StarTech.com Displayport to HDMI Adapter - 4K30 - DPCP & HDCP - DisplayPort 1.2 to HDMI 1.4 - Apple HDMI Adapter (DP2HD4KADAP) - adapter - DisplayPort / HDMI
- Cable
- Adapter - DisplayPort / HDMI
- Max Output Resolution
- 3840 x 2160 - 30 Hz
- Black
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - female
- DisplayPort 1.2/DisplayPort++
- Passive adapter, 4K30Hz (3840 x 2160) support
- 3-year warranty
- Designed For
- P/N: TB2DOCK4K2DP
- Cable Type
- Adapter passive, 4K30Hz (3840 x 2160) support
- Interface Supported
- DPCP compliant, 7.1 channel Surround Sound
- Black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 30 Hz
- OS Required
- Apple MacOS, Microsoft Windows, Ubuntu
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - female
- FCC, RoHS, HDCP 1.4
- 2.1 cm
- 6.4 cm
- 1.1 cm
- 7.5 g
- Shipping Width
- 9.8 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 2.6 cm
- Shipping Weight
- 36 g
- Limited warranty - 3 years
- Designed For
- P/N: TB2DOCK4K2DP
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £12.84 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £11.50 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.86 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £15.98 |
StarTech.com HDMI or DVI to DisplayPort Active Converter | In Stock | £82.20 |
StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £11.42 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.38 |
StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £21.47 |
StarTech.com 6 ft DP to HDMI cable - 4K | In Stock | £15.82 |
StarTech.com DisplayPort to HDMI - 4K | In Stock | £15.02 |
StarTech.com HDMI to DisplayPort Converter - 4K | In Stock | £39.46 |
