Conveniently label and organize cable runs, using this 100-pack of 3.5in (9cm) Hook-to-Hook Cable Tags.
IT Pro-Level Cable Management
These hook-to-hook style fastener straps provide a quick and clean solution to cable tagging. The tags are free of any adhesives, enabling quick and residue-free removal. The tags function as write-on labels to provide clear and concise cable identification in high-density cabling environments, such as data centers and server rooms. -
Flexible Use
The hook-to-hook cable labels are suitable for use with permanent or dark ink marker to identify cables and wired IT peripherals. The cable tags are simple to apply and remove. This 100 pack of labels can be used to organize multiple setups. Add these to your kit, to ensure all new cable connections are labelled immediately.
- StarTech.com 3.5in (9cm) Cable Labels, 100 Pack White, Cable/Cord Tags (CABLE-TAG-HLWH) - cable identification labels - hook-to-hook fastener, write-on
- Product Type
- Cable identification labels - hook-to-hook fastener, write-on
- Packaged Quantity
- 100 (specifications are for single item)
- 1.9 cm
- Length
- 9 cm
- White
- 2-year warranty
- Packaged Quantity
- Product Type
- 1.9 cm
- Length
- 9 cm
- Enclosure Colour
- White
- Write-on, self-gripping
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 2.8 cm
- Shipping Weight
- 92 g
- Limited warranty - 2 years
- -10 °C
- 80 °C
StarTech.com Cable Management Sleeve - 2 m | In Stock | £10.76 |
StarTech.com Dual-Module Conference Table Connectivity Box | In Stock | £187.64 |
StarTech.com Under Desk Cable Management Tray - Cord/Wire Organizer | In Stock | £21.87 |
