Add safe and reliable swappable storage from a single 5.25in front bay. This high quality Removable SATA Hard Drive Drawer/Mobile Rack delivers a convenient SATA hot-swap solution, allowing you to quickly swap Serial ATA hard drives in and out of a computer without having to open the computer case.
Simply install the (included) drive bay into a 5.25in drive bay on the host computer, then mount a 3.5in SATA HDD in the (removable) caddy. Connecting the SATA hard drive to the computer is as easy as inserting the caddy into the drive bay, which can be locked to prevent unauthorized removal of the installed SATA drive.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
A suitable solution for large volume drives, the HDD drawer supports SATA, SATA II, and SATA III-6Gbps hard drives allowing you to swap in large amounts of data in a matter of seconds. The mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
The drive caddy features a rear panel ball bearing fan that helps keep the enclosed drive cool, in turn helping to optimize operation while preserving drive lifespan. To prevent damage to the hard drive(s) while being transferred in and out of the computer, the drive caddy features shock absorbers and rubber cushioning that help limit vibration/shock to the drive. This mobile rack is also compatible with DRW113-series SATA hard drive caddies.
A dependable, long-lasting storage solution, the drive drawer features highly durable construction, with a 3K insertion rating.
- StarTech.com Value Series Black 5.25in SATA Hard Drive Mobile Rack Drawer - storage bay adapter
- Storage bay adapter
- Black
- Expansion Bays
- 1 x internal - 3.5"
- Compatible Bay
- 1 5.25" x 1/2H
- Supported Interface
- SATA 1.5Gb/s
- Drive Connector
- 7 pin Serial ATA
- Bay Connector
- 7 pin Serial ATA
- Ball bearing cooling fan, data indicator, power indicator, shock protection, key lock, cooling fan
- Product Material
- Plastic
- 14.8 cm x 22 cm x 4.1 cm
- 0.5 kg
- 2-year warranty
- Product Material
- Plastic
- Black
- SATA 1.5Gb/s
Storage Controller
- Processor
- No CPU
- Bays
- 1 x SATA 1.5Gb/s - SATA
- Connections
- 1 storage - Serial ATA-150 - 7 pin Serial ATA
- Compatible Bay
- 1 x external 5.25" x 1/2H
- Limited warranty - 2 years
- 14.8 cm
- 22 cm
- 4.1 cm
- 0.5 kg
StarTech.com 12in Latching SATA Cable | In Stock | £6.16 |
StarTech.com 18in Latching SATA Cable | In Stock | £4.24 |
StarTech.com 24in Latching SATA Cable | In Stock | £6.84 |
Customer reviews
Write a review for the StarTech.com Black 5.25in SATA Hard Drive Mobile Rack Drawer here!
Great item
Reviewed by Anonymous Review Posted 21/10/2007
'Cheap as chips'. DABS usual super fast delivery. Easy to fit and works straight out of the box.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
