Swap SATA hard drives in and out of a PC or server, quickly and securely. This high quality Removable SATA Hard Drive Drawer/Mobile Rack delivers a professional-grade SATA hot-swap solution, allowing you to quickly swap Serial ATA hard drives in and out of a computer without having to open the computer case.
Simply install the (included) drive bay into a 5.25in drive bay on the host computer, then mount a 3.5in SATA HDD in the (removable) caddy. Connecting the SATA hard drive to the computer is as easy as inserting the caddy into the drive bay, which can be locked to prevent unauthorized removal of the installed SATA drive.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
A practical, time-saving hot swap solution, the drive drawer includes Swap Manager utility software that lets users swap drives in and out of the host computer without powering down the computer.
A suitable solution for large volume drives, allowing you to swap in large amounts of data in a matter of seconds. With support for SATA HDD speeds up to 6.0 Gbps, the mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
The drive caddy features two front panel ball bearing fans that help keep the enclosed drive cool, in turn helping to optimize operation while preserving drive lifespan. To prevent damage to the hard drive(s) while being transferred in and out of the computer, the drive caddy features shock absorbers and rubber cushioning that help limit vibration/shock to the drive.
A dependable, long-lasting storage solution, the drive drawer/mobile rack features highly durable aluminum construction, with a 7K insertion rating.
- StarTech.com Black Aluminum 5.25in Professional SATA Mobile Rack - storage mobile rack
- Storage mobile rack
- Black
- Expansion Bays
- 1 x internal - 3.5"
- Compatible Bay
- 1 5.25" x 1/2H
- Supported Interface
- SATA 3 Gb/s
- Drive Connector
- 7 pin Serial ATA
- Bay Connector
- 7 pin Serial ATA
- 2 fans, ball bearing cooling fan, data indicator, power indicator, shock protection, fan status indicator, key lock, temperature indicator, cooling fan
- Product Material
- Plastic, aluminium
- 14.8 cm x 22 cm x 4.1 cm
- 1 kg
- 2-year warranty
- Designed For
- P/N: PEXMSATA3422, PEXMSATA343, PEXSAT34RH
- Product Material
- Black
- SATA 3 Gb/s
Storage Controller
- Processor
- No CPU
- Bays
- 1 x SATA 3Gb/s - SATA
- Connections
- 1 storage - Serial ATA-300 - 7 pin Serial ATA
- Compatible Bay
- 1 x external 5.25" x 1/2H
- Limited warranty - 2 years
- 14.8 cm
- 22 cm
- 4.1 cm
- 1 kg
- Designed For
Customer reviews
Write a review for the StarTech.com Black Aluminum 5.25in Professional SATA Hard Drive Mobile Rack Drawer here!
Lacks OS support
Reviewed by kayakrage. Review Posted 08/09/2010
The software provides is not supported on the new OS such as Windows 7 and Windows Server 2008. You machines motherboard and BIOS will need to support hot swap drives for it work under those circumstances. The drive caddy does not fit all macines easily.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
