Add headphone and MIC audio connectors through USB.
This USB Audio adapter converts a USB port to an audio port, allowing you to add headsets and microphones to your computer without the need to unplug other devices!
Compliant with USB 2.0 and USB audio device specification 1.0, the USB audio adapter couldn't be any simpler to install...it's as easy as connecting the adapter to an available USB 2.0 port, then connecting your audio devices to the provided 3.5 mm audio ports as needed.
Compatible with Windows 98SE and up, as well as Mac OS 9.x and later, the adapter integrates into any computer environment, providing superb sound quality and convenience that can't be matched.
- StarTech.com USB Stereo Audio Adapter External Sound Card - sound card
- Sound card
- Enclosure Type
- External
- Interface Type
- Hi-Speed USB
- 4 cm x 8 cm x 1.5 cm
- 54 g
- Sound Output Mode
- Stereo
- System Requirements
- Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
- 2 years warranty
- Sound card
- Form Factor
- External
- Interface Type
- Hi-Speed USB
- 4 cm
- 8 cm
- 1.5 cm
- 54 g
- Enclosure Colour
- Black
Audio Output
- Sound Output Mode
- Stereo
- 1 x audio line-in/microphone - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
- FCC, RoHS
- Software
- Drivers & Utilities
- OS Required
- 2 years warranty
- Service & Support Details
- Limited warranty - 2 years , Technical support - lifetime
