Connect two DVI monitors to your DMS / LFH equipped graphics card.. This DMS 59 to dual DVI Y cable allows you to break out one LFH 59 or LFH 60 (DMS 59 and DMS 60) connection on Matrox Qid, nVidia Quadro, and PNY Quadro graphics cards into two DVI-I Dual Link female connectors - letting you connect two DVI capable monitors for a cost-effective dual monitor solution.
- StarTech.com DMS 59 to Dual DVI I - 8in - DMS 59 to 2x DVI - Y Cable - DVI Splitter Cable - Monitor Splitter Cable - DMS 59 Cable (DMSDVIDVI1) - DVI cable - 20 cm
- DVI cable - dual link
- Length
- 20 cm
- Connector
- 2 x DVI-I - female
- Connector (Second End)
- DMS-59 - male
- RoHS
- Black
- Limited lifetime warranty
- DVI cable
- TMDS Links
- Dual link
- Length
- 20 cm
- Black
- Connector
- 2 x 24+5 pin combined DVI - female
- DMS-59 - male
- RoHS
StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F | In Stock | £12.97 |
StarTech.com 8in LFH 59 Male to Dual Female DisplayPort DMS 59 Cable | In Stock | £17.97 |
