StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female
Quicklinx: 8D4SWS00 Mfr#: DVIVGAMF8IN
13 In Stock
£7.53 ex VAT
£9.03 inc VAT
Connect your VGA display to a DVI-I source. The DVIVGAMF8IN DVI to VGA cable (8-inch) is used to adapt a DVI male connector to a VGA female connector and enables you to connect a flat panel display to a PC or MAC computer with DVI-I output.
The VGA female connection added by the dongle is situated approximately 8 inches away from the DVI output connection, which lessens strain on and prevents damage to the DVI connector while reducing the potential of blocking other available ports.
The DVI male to VGA female adapter is constructed of high quality materials to ensure dependability.
StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female Dongle Adapter (DVIVGAMF8IN) - VGA adapter - 20 cm
VGA adapter
Shielded
Thumbscrews
Length
20 cm
Connector
DVI-I - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
VGA adapter
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Thumbscrews
Length
20 cm
Connector
24+5 pin combined DVI - male
15 pin HD D-Sub (HD-15) - female
RoHS
8D4S StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.42
8D4S StarTech.com DVI to VGA Cable Adapter - Black - M/F In Stock £6.13
8D4S StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female In Stock £7.53
