StarTech.com 6U 19in Wallmount Server Rack Cabinet with Acrylic Door
Quicklinx: 7TXCWS00 Mfr#: RK619WALLGB
Mount network and telecom equipment to the wall, with this lockable 6U wallmount cabinet. The RK619WALLGB Wall-Mounted 6U Server Rack/Cabinet can be fastened to most types of walls and features a sturdy, compact design that can be positioned almost anywhere, without wasting valuable floor space.
This equipment rack offers 6U of storage space and is designed to accommodate 19-inch (wide) servers, networking and telecom equipment. The rack features a 12cm fan, with ventilation positioned above and below the front panel glass door, helping to keep dust out of the rack while ensuring a cool operating environment for your valuable equipment.
To ensure optimum security and prevent tampering with the enclosed equipment, the cabinet/rack features a lockable, smoked acrylic front door that can be removed entirely or installed to open to the left or right as needed.
StarTech.com 6U Patch Panel Cabinet - 19in Wall Mount Network Cabinet with Acrylic Door - Data Rack for a Server Room (RK619WALL) - rack - 6U
Rack
Rack Type
Cabinet
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
6U
Product Material
Steel, acrylic
56 cm x 40 cm x 33 cm
10.5 kg
Lockable front door, fan top, window style door
Rack
Rack Type
Cabinet
Placing / Mounting
Wall mountable
Product Material
Steel, acrylic
Rack Size
19"
Height (Rack Units)
6U
56 cm
40 cm
33 cm
10.5 kg
Weight Limit
50 kg
UL, RoHS
Limited warranty: - lifetime
7TXC StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £19.93
7TXC StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £83.08
7TXC StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.74
7TXC StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £35.39
7TXC StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.34
7TXC StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £12.78
7TXC StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £16.28
7TXC StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £32.84
7TXC StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £62.33
7TXC StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £65.84
7TXC StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £35.51
7TXC StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.16
7TXC StarTech.com 1U Server Rack Panel In Stock £13.04
7TXC StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £59.69
7TXC StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £32.13
7TXC StarTech.com 50 Pkg M6 Cage Nuts In Stock £22.74
7TXC StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.56
7TXC StarTech.com 50 Pkg M5 Cage Nuts In Stock £17.25
7TXC StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £62.33
7TXC StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £32.84
7TXC StarTech.com 50 Pkg M5 Mounting Screws In Stock £18.34
7TXC StarTech.com 100 Pkg M5 Mounting Screws In Stock £34.53
7TXC StarTech.com 50 Pkg M6 Mounting Screws In Stock £19.35
7TXC StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.55
7TXC StarTech.com 100 Pkg M6 Cage Nuts In Stock £30.84
7TXC Startech.com 100 Pkg M6 Mounting Screws In Stock £28.59
7TXC StarTech.com 19in Cable Management Panel In Stock £24.78
7TXC StarTech.com M6 Mounting Screws 50Pack In Stock £17.54
