This 6ft IEEE 1394 FireWire Cable provides two 4-pin FireWire male connectors and is expertly designed and constructed of high quality materials to ensure optimum performance and reliability.
Capable of data transfer rates of up to 400Mbps, FireWire technology provides a high speed link that saves time during large file transfers (e.g. transferring digital video files from a DV camcorder to a computer, etc.). This high quality cable is manufactured using IEEE-1394 rated wire for full FireWire 400 reliability and compatibility.
- StarTech.com 6 ft IEEE-1394 Firewire Cable 4-6 M/M - IEEE 1394 cable - 4 PIN FireWire to 6 PIN FireWire - 1.8 m
- IEEE 1394 cable
- Length
- 1.8 m
- Connector
- 4 PIN FireWire - male
- Connector (Second End)
- 6 PIN FireWire - male
- IEEE 1394
- Limited lifetime warranty
- Designed For
- P/N: CB1394_2, EC13942, MPEX1394B3, PCI1394MP, PEX1394B3LP
- IEEE 1394 cable
- Length
- 1.8 m
- Connector
- IEEE 1394
- Designed For
