This open SFP PoE fiber media converter offers an easy, inexpensive way to extend the reach of your data and power devices at remote locations using your network over fiber, using the SFP of your choice. It combines the data connectivity of a media converter with the flexible power supply capabilities of a PoE injector. The converter provides a powerful networking solution for campuses, warehouses, factories or any applications that require POE and connectivity over long distances.
Designed for harsh environments
This media converter can be installed almost anywhere you need it as it has been engineered to work in environments with large temperature changes. -
Open SFP slot to leverage your current infrastructure
The Gigabit fiber media converter provides a cost-efficient way to connect remote devices over a fiber link. -
Dual power inputs
Accepts terminal block power or coaxial power connectors with the barrel plug adapter, allowing the product to be hardwired or powered using an external power supply.
- StarTech.com PoE+ Industrial Fiber to Ethernet Media Converter 60W, SFP to RJ45, Singlemode/Multimode Fiber to Copper Gigabit Ethernet, Compact, IP-30/ -40 to +75C, PoE+ Media Converter - Fiber Media Converter (IMC1GSFP60W) - fibre media converter - 10Mb LAN, 100Mb LAN, GigE
- Fibre media converter - RJ-45 / SFP (mini-GBIC)
- Form Factor
- DIN rail mountable
- Cabling Type
- 1000Base-SX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- Max Transfer Distance
- 10 km
- Power Over Ethernet (PoE)
- PoE+
- 8.15 cm x 10.4 cm x 3.2 cm
- 153 g
- 2-year warranty
- Form Factor
- Black
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 10 km
- Status Indicators
- Port status, active, PoE, link
- Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode, 512KB packet buffer, 2KV Surge protection, 16 KB Jumbo Frame
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3x
- 1 x Ethernet 1000Base-T - RJ-45 female - 60 W , 1 x Ethernet 1000Base-SX - SFP female
- Included Accessories
- Power terminal block
- Mounting Kit
- Included
- MTBF
- 561556 hours
- IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, EN 60950-1, WEEE, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6, IEEE 802.3af, IEEE 802.3at
- PoE+
- Power Device
- External power adapter
- 8.15 cm
- 10.4 cm
- 3.2 cm
- 153 g
- Shipping Width
- 21.1 cm
- Shipping Depth
- 16.2 cm
- Shipping Height
- 6.4 cm
- Shipping Weight
- 400 g
- Limited warranty - 2 years
- -40 °C
- 75 °C
- 5 - 95% (non-condensing)
