Connect and power your external mini-USB equipped hard drive through two standard USB ports on your computer. The USB2HABMY6 6 ft USB-A to Mini-B Y cable features two USB-A male connectors and a single USB Mini-B male connector - an ideal solution for providing additional power to your mini-USB external hard drive by connecting to two USB-A ports on your computer or laptop.
Especially valuable in situations where a single USB 2.0 port may not offer sufficient power to external hard drives, the USB2HABMY6 can be connected to two ports on one PC to increase the power output to power the external device.
- StarTech.com 6 ft USB Y Cable for External Hard Drive - USB A to mini B - USB cable - USB (M) to mini-USB Type B (M) - USB 2.0 - 6 ft - black - USB2HABMY6 - USB cable - USB to mini-USB Type B - 1.8 m
- USB cable
- Length
- 1.8 m
- Connector
- 2 x 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: SAT1810U2, SLMSOPTB, PEXUSB7LP
- USB cable
- American Wire Gauge (AWG)
- 24/28
- Length
- 1.8 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
- StarTech.com 1.8in USB to Micro SATA Hard Drive Enclosure, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, USB to Slimline SATA CD/DVD Optical Drive Enclosure
StarTech.com Mini USB to Micro USB Adapter | In Stock | £4.82 |
StarTech.com 6 ft USB Y Cable for External Hard Drive - USB A to mini B | In Stock | £4.95 |
StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable | In Stock | £4.95 |
