Create Ultra HD connections between your HDMI -enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM6HS 6-foot High Speed HDMI Cable with Ethernet supports the advanced capabilities of the High-Definition Multimedia Interface, including Ethernet data inter-connectivity with compatible HDMI-enabled products, and is fully backward compatible with older HDMI-capable devices.
The cable features gold-plated HDMI (male) connectors which help to ensure a high quality digital connection capable of transmitting high-definition video and multi-channel audio between devices such as Blu-Ray Disc players, HDTVs, DVD Players, DVRs, stereo receivers and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
All StarTech.com High Speed HDMI Cables are expertly designed and constructed of top quality materials to deliver dependable high-definition performance.
- StarTech.com 6ft HDMI Cable, 4K High Speed HDMI Cable with Ethernet, 4K 30Hz UHD HDMI Cord, 10.2 Gbps Bandwidth, 4K HDMI 1.4 Video / Display Cable M/M, 28AWG, ARC, HDCP 1.4, CEC - Durable Black HDMI Cable - HDMI cable with Ethernet - 1.8 m
- Cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Length
- 1.8 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- HDMI Ethernet Channel (HEC)
- Limited lifetime warranty
- Designed For
- P/N: LENYMCHDVUGK, SV431DHD4KU, SV431HDU3A2
- Cable Type
- Technology
- Double shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1.8 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
- Designed For
