StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black
Quicklinx: 964VWS00 Mfr#: DP2DVIMM6BS
Length: 1.8m
29 left in stock
£23.85 ex VAT
£28.62 inc VAT
Connect a DisplayPort-equipped PC to a DVI display, with an active 6ft cable. The DP2DVIMM6BS 6ft active DisplayPort to DVI converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a DVI monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your new DisplayPort computer to work with an older VGA monitor or projector.
For guaranteed compatibility with virtually any DisplayPort output the active DisplayPort to DVI adapter supports multimode (DP++) as well as single-mode DisplayPort signals. Unlike passive adapters, this ensures the DP2DVIMM6BS can be used with graphics cards that are not capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
Plus, because the converter cable supports video resolutions up to 2560x1600 you can convert a DisplayPort video source to DVI without sacrificing video quality.
  • DisplayPort to DVI cable
    6ft (1.8m) Active DisplayPort 1.2 (HBR2) to DVI-D single-link cable connects a DVI display, monitor, projector, 1920x1200/1080p 60Hz or 4K 30Hz (HDMI clock rate); EDID pass-through ensures compatibility between source & display.
  • Compatibility
    Active video converter supports DP (single mode) or DP++ (multi-mode) source including workstations, desktops (AMD/NVIDIA), laptops, small form factor computers & docking stations.
  • Integrated display cable
    DisplayPort to DVI adapter cable has slim & flexible design w/adapter chip built into DVI connector reducing clutter & providing a tidy install in the office, boardroom or home office.
  • Latching DisplayPort & screw locking DVI
    Latching DP connector ensures a solid host connection, and chip built into DVI connector minimizes signal loss. Supports DVI screw locking cable to prevent cable from coming loose or accidental disconnection.
  • Easy to use
    With no software or drivers required, the DP to DVI cable/cord works with any OS including Windows, Ubuntu and macOS; DisplayPort male to DVI male cable.
StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable - 6ft (1.8m) Active DP to DVI M/M Cable for PC - 1920x1200 - Black (DP2DVIMM6BS) - display cable - 1.8 m
Display cable
Active cable (signal regeneration)
Length
1.8 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
P/N: MST30C2DPPD, TB3CDK2DP, TB3CDK2DPUE, TB3CDOCKDP, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Display cable
Length
1.8 m
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
964V StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £22.11
964V StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £23.82
964V StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
964V StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £14.24
964V StarTech.com DisplayPort to DVI Active Adapter In Stock £22.72
964V StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F In Stock £9.57
964V StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £10.14
964V StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £55.60
964V StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £23.85
964V StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 Black In Stock £9.17
964V StarTech.com 3ft DP to DVI Converter Cable In Stock £16.71
Length: 1.8m
Stock Status: While stocks last
Stock Status: Clearance
