Connect a DisplayPort-equipped PC to a DVI display, with an active 6ft cable. The DP2DVIMM6BS 6ft active DisplayPort to DVI converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a DVI monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your new DisplayPort computer to work with an older VGA monitor or projector.
For guaranteed compatibility with virtually any DisplayPort output the active DisplayPort to DVI adapter supports multimode (DP++) as well as single-mode DisplayPort signals. Unlike passive adapters, this ensures the DP2DVIMM6BS can be used with graphics cards that are not capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
Plus, because the converter cable supports video resolutions up to 2560x1600 you can convert a DisplayPort video source to DVI without sacrificing video quality.
DisplayPort to DVI cable
6ft (1.8m) Active DisplayPort 1.2 (HBR2) to DVI-D single-link cable connects a DVI display, monitor, projector, 1920x1200/1080p 60Hz or 4K 30Hz (HDMI clock rate); EDID pass-through ensures compatibility between source & display. -
Compatibility
Active video converter supports DP (single mode) or DP++ (multi-mode) source including workstations, desktops (AMD/NVIDIA), laptops, small form factor computers & docking stations. -
Integrated display cable
DisplayPort to DVI adapter cable has slim & flexible design w/adapter chip built into DVI connector reducing clutter & providing a tidy install in the office, boardroom or home office. -
Latching DisplayPort & screw locking DVI
Latching DP connector ensures a solid host connection, and chip built into DVI connector minimizes signal loss. Supports DVI screw locking cable to prevent cable from coming loose or accidental disconnection. -
Easy to use
With no software or drivers required, the DP to DVI cable/cord works with any OS including Windows, Ubuntu and macOS; DisplayPort male to DVI male cable.
- StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable - 6ft (1.8m) Active DP to DVI M/M Cable for PC - 1920x1200 - Black (DP2DVIMM6BS) - display cable - 1.8 m
- Display cable
- Active cable (signal regeneration)
- Length
- 1.8 m
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-D - male
- FCC, RoHS
- Black
- 3-year warranty
- Designed For
- P/N: MST30C2DPPD, TB3CDK2DP, TB3CDK2DPUE, TB3CDOCKDP, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
- Display cable
- Length
- 1.8 m
- Black
- Connector
- 20 pin DisplayPort - male
- 24+1 pin digital DVI - male
- FCC, RoHS
- 3-year warranty
- Designed For
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £22.11 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £23.82 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.86 |
StarTech.com 6 ft DisplayPort to DVI Cable - M/M | In Stock | £14.24 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.72 |
StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F | In Stock | £9.57 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £10.14 |
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £55.60 |
StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £23.85 |
StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 Black | In Stock | £9.17 |
StarTech.com 3ft DP to DVI Converter Cable | In Stock | £16.71 |
