StarTech.com 50-Pack M5 Screws - 10mm Long Computer/PC Case Fan Screws
Quicklinx: GB6CWS00 Mfr#: M5FANSCREW10
Device Type: Desktop Computer
Type: Screw Kit
Device Screen Size: [N/A]
Colour: [N/A]
20 left in stock
£3.16 ex VAT
£3.79 inc VAT
Express delivery Order within the next 15 hours for delivery tomorrow
Steel - Zinc Plated - Phillips Head - M5 Thread - 10 mm - 50-Pack
This 50 pack of M5 screws are used to secure standard case fans with M5 mounting holes. 50 individual screws are including making this an ideal solution for IT departments or repair shops that require plenty of screws on hand for new system builds or upgrades.
High-Quality Screws
These screws are manufactured using high-quality steel and feature a nickel plating. Each screw has a flat Philips head and an M5 thread and are 10 mm in length.
Easy Installation
The screws are self-tapping and install easily into threadless holes and can be installed using a standard Phillips head (cross head) screwdriver.
M5FANSCREW10 is backed by a StarTech.com lifetime warranty and free lifetime 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
  • High-quality screws
  • Easy installation
StarTech.com 50-Pack M5 Screws, 10mm Long Computer/PC Case Fan Screws, Self-Tapping Computer Case Fan Mounting Screws, Phillips/Flat Head, Fits M5 Fan Holes, Steel Zinc Plated - Computer Case Fan Screws (M5FANSCREW10) - screw kit
Screw kit
Package Content
50 M5 screws
Silver
Product Material
Nickel-plated steel
0.63 cm x 1.12 cm x 0.63 cm
Screw kit
Product Material
Nickel-plated steel
Package Content
50 M5 screws
0.63 cm
1.12 cm
0.63 cm
9 cm x 11.9 cm x 1 cm / 40 g
Silver
RoHS
Limited warranty: - 2 years
GB6C StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.82
Type: Screw Kit
Colour: [N/A]
Stock Status: While stocks last
Stock Status: Clearance
