Your basket is empty
StarTech.com 50' Cat5e Patch Cable Blue
Quicklinx: 3ZZMWS00 Mfr#: M45PATCH50BL
Length: 15.2m
£10.69 ex VAT
£12.82 inc VAT
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT50BL Cat5e Patch Cable (50 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
StarTech.com Molded Cat 5e UTP Patch Cable - patch cable - 15.2 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wire(s)
Moulded
Length
15.2 m
Connector(s)
1 x RJ-45 - male
Connector(s) (Other Side)
1 x RJ-45 - male
Blue
P/N: ST121UTPDVEU, ST124UTPEAGB, ST128UTPEAGB, STUTPEALRGB, ST121UTP23GB, ST121UTPDVGB, ST128UTPEA, ST121HDMR50, ST121HDMIT, STUTPEALR, ST124UTPEA, PEX100S, ST121UTPDVI, NETRS2321E, ST121UT232GB, ST121UTP232, PS2UTPEXT, STUTPRXL, ST128UTPE, ST124UTPE, NETRS232_4GB, USB6N1DOCKGB, RS232EXTC5
Network Cable Type
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wire(s)
Pairs per Cable
4 pair(s)
Moulded
Length
15.2 m
Blue
Connector(s)
1 x RJ-45 - male
1 x RJ-45 - male
UL
StarTech.com 1 Port Cat5 USB Extender, 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card, 1 Port RS-232/422/485 Serial over IP Ethernet Device Server, 4 Port VGA Video Extender over Cat 5 (UTPE Series), 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator, 8 Port VGA and Audio over Cat 5 Video Extender, 8 Port VGA Video Extender over Cat 5 (UTPE Series), DVI Video Extender over Cat5, HDMI over Cat 5 Video Extender - Receiver, HDMI Video Extender over Cat 5, PS/2 Keyboard and Mouse Extender over Cat 5, RS-232 Serial Ethernet IP Adapter (Device Server, Console Server), Serial DB9 RS232 Extender over Cat 5 - Up to 3300 ft (1000 meters), VGA Video Extender over Cat 5 Remote Receiver with Audio, VGA Video Extender over Cat 5 with RS232 , StarTech.com Converge A/V 4 Port VGA and Audio over Cat 5 Video Extender, HDMI Over CAT5 / UTP Receiver , StarTech.com USBthere 4 Port 100m USB Extender
Length: 15.2m
Colour: Blue
Price Range Ex VAT: 0 - 50
