StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket
Quicklinx: 6B9WWS00 Mfr#: RK419WALLV
Product Type: Mounting bracket
£53.59 ex VAT
£64.30 inc VAT
This 4U 19in Wallmount Bracket offers a versatile storage solution, allowing equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with wall) to save space. Alternatively, the 4U bracket can be installed under a desk for horizontal installation, making it easy to access installed equipment directly from your workspace.
Perfect for SoHo (small office, home office) environments, the wallmount bracket offers space-saving installation for environments lacking the footprint space for a full size server equipment rack.
Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes (used to mount to a wall or the desk underside) are positioned at exactly 16in apart, matching standard construction framework.
Constructed to EIA-310 19in rack standards, the wallmount bracket features a sturdy steel design.
Need more storage space? StarTech.com also offers a 1U 19in Wallmount Bracket, a 2U 19in Wallmount Bracket and a 3U 19in Wallmount Bracket.
StarTech.com 4U Wall Mount Patch Panel Bracket - 19 inch Steel Vertical Mounting Bracket for Network and Data Equipment (RK419WALLV) - mounting bracket - 4U
Mounting bracket
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
4U
Product Material
Steel
5 cm x 19.4 cm x 15.1 cm
1.06 kg
Mounting bracket
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
4U
5 cm
19.4 cm
15.1 cm
1.06 kg
Mounting Kit
Included
UL, RoHS
Limited warranty: - lifetime
6B9W StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £19.93
6B9W StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £45.21
6B9W StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £39.32
6B9W StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £53.59
6B9W StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.74
6B9W StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £35.39
6B9W StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £48.99
6B9W StarTech.com 1U 19in Hinged Wall Mounting Bracket for Patch Panels In Stock £16.66
6B9W StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £16.28
6B9W StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £32.84
6B9W StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £62.33
6B9W StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £65.84
6B9W StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £35.51
6B9W StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.16
6B9W StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £65.84
6B9W StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £32.13
6B9W StarTech.com 50 Pkg M6 Cage Nuts In Stock £22.74
6B9W StarTech.com 100 Pkg M5 Cage Nuts In Stock £34.53
6B9W StarTech.com 50 Pkg M5 Cage Nuts In Stock £17.25
6B9W StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £62.33
6B9W StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £32.84
6B9W StarTech.com 50 Pkg M5 Mounting Screws In Stock £18.34
6B9W StarTech.com 100 Pkg M5 Mounting Screws In Stock £34.53
6B9W StarTech.com 50 Pkg M6 Mounting Screws In Stock £19.35
6B9W StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.55
6B9W StarTech.com 100 Pkg M6 Cage Nuts In Stock £30.84
6B9W Startech.com 100 Pkg M6 Mounting Screws In Stock £28.59
6B9W StarTech.com 19in Cable Management Panel In Stock £24.78
6B9W StarTech.com 4U WM Server Rack with Shelf In Stock £103.46
6B9W StarTech.com 8U WM Server Rack with Shelf In Stock £137.20
6B9W StarTech.com 6U Wall Mount Rack Bracket In Stock £73.86
6B9W StarTech.com 18U Server Rack Enclosure In Stock £452.59
6B9W StarTech.com 6U Wall-Mount Rack Cabinet In Stock £149.52
6B9W StarTech.com 26U Server Rack Enclosure In Stock £495.72
6B9W StarTech.com 9U Wall-Mount Rack Cabinet In Stock £175.15
6B9W StarTech.com 9U Wall-Mount Rack Cabinet In Stock £194.68
6B9W StarTech.com 12U Server Rack Enclosure In Stock £402.13
6B9W StarTech.com 12U Server Rack Enclosure In Stock £277.35
6B9W StarTech.com 15U Server Rack Enclosure In Stock £344.58
6B9W StarTech.com 12U Server Rack Enclosure In Stock £377.14
6B9W StarTech.com M6 Mounting Screws 50Pack In Stock £17.54
