Add four external USB 3.0 ports and phone charging capability to your laptop with this portable hub. This 4-port USB 3.0 hub turns a single USB port on your laptop into four USB-A ports and features a compact, USB-powered design that makes it perfect for travel. For devices that demand extra power, the hub also comes with an external power adapter.
With its compact and lightweight design, this 4-port USB hub is tailored for mobility. You can easily tuck it into your laptop bag when traveling, which makes it easy to expand your connection options almost anywhere you need to. It's perfect for connecting common USB devices such as a mouse, keyboard, or flash drive, right when you need them.
You can install the versatile USB 3.0 hub virtually anywhere, because it takes up minimal space on a desk, and fits perfectly in hot-desk or BYOD environments.
This self-powered USB hub comes with an external power adapter to support power-hungry USB devices, such as larger external drives and enclosures, which require more power than USB power can provide on its own.
With the power adapter, you can also charge your smartphone on one of the available ports. Each USB-A port supports USB Battery Charging Specification 1.2. It's recommended to only charge one device at a time.
This USB 3.0 hub will work with a wide range of computers because it requires no additional software or drivers. It installs automatically when you connect it to your laptop or desktop, so you can be up and running quickly. It also works with a range of operating systems such as Windows, macOS, Linux and Chrome OS, so it's multi-platform compatible.
- StarTech.com 4 Port USB 3.0 Hub SuperSpeed 5Gbps with Fast Charge Portable USB 3.1/USB 3.2 Gen 1 Type-A Laptop/Desktop Hub, USB Bus Power or Self Powered for High Performance, Mini/Compact - 15W of Shared Power (ST4300MINI) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB powered
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 120/230 V
- 4 cm x 9 cm x 1.5 cm
- 280 g
- Black
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- 2-year warranty
- Designed For
- P/N: USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- Processor
- X VIA Labs VL812
- 4 x USB 3.0 Type A charging port
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- MTBF
- 40,103 hours
- Plug and Play, FCC, RoHS, USB Battery Charging Specification Rev. 1.2
- Localisation
- 4 cm
- 9 cm
- 1.5 cm
- 280 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- Min Storage Temperature
- -50 °C
- Max Storage Temperature
- 120 °C
- Designed For
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.53 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £15.49 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £16.73 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black | In Stock | £21.36 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £23.49 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £52.14 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.70 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £71.57 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £26.82 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.55 |
StarTech.com 7 Port Compact USB 3.0 Hub | In Stock | £48.93 |
StarTech.com 4-Port USB 3 Hub + 2.4A DCP | In Stock | £43.39 |
StarTech.com 7-Pt USB 3.0 Hub + Charge Pts | In Stock | £60.86 |
