MANAGED USB HUB:USB Hub Administrator software works with the USB hub to enable/disable ports or all ports and reboot the Hub; Windows, macOS, Linux; Supports CLI commands for custom application creation.
ROBUST and RELIABLE: With metal housing, 15kV/8kV level 4 ESD air/contact protection, this rugged USB 3.2 Gen 1 5Gbps hub reliably connects 4 USB devices in harsh industrial environments.
POWER AND CHARGING: USB hub supports 7 to 48 volts DC; powered via terminal block connector with power adapter (part number: ITB20D3250); 3x USB-A ports capable of charging BC 1.2 (2.4A).
VERSATILE MOUNTING OPTIONS: This mountable USB hub installs securely on/under a desk, wall or DIN rail using the integrated mounting ears and DIN brackets included; 1.8 m USB 3.2 Gen 1 cable included.
CONNECTIVITY TOOLS: Includes Connectivity Tools application, enabling administrators to identify potentially malicious devices; TAA-compliant; Ideal for remote operations and device security.
Managed USB Hub
USB Hub Administrator software must be installed on the host computer, enabling users to remotely control access to peripherals and manage operational features. With this software, users can: - Enable or disable individual or all USB Hub ports. - Restart the USB Hub. - Set a password to restrict unauthorized access. - Save port states for quick configuration in specific applications. - Use command line commands (CLI) for command line operations or custom application development. The software is compatible with Windows, macOS and Linux, making it versatile on different platforms. It supports an unlimited number of managed USB Hubs, enabling users to connect multiple Hubs to a single host computer, or cascade them in sequence. -
Robust and reliable
The Industrial USB Hub features a robust metal housing designed to protect the hub from potential damage caused by accidental drops or sudden shocks. What's more, it offers protection against electrostatic discharge (ESD) up to 15 kV in air and 8 kV in contact, in compliance with ESD protection level 4. This robust construction guarantees resilience in demanding industrial environments, offering peace of mind to users in situations where durability and reliability are essential. -
Flexible power supply
The USB Hub offers power supply flexibility to meet the diverse needs of users. It features a terminal block power input that supports a wide voltage range from +7 to 48 volts DC, ensuring compatibility with a variety of power sources. With an external power source connected, the USB Hub supports the USB 1.2 battery charging specification, delivering up to 1.5 A (7.5 W) on 3 of the downstream ports, enabling you to quickly power and charge external devices. For optimum performance, an external power source is required. StarTech.com offers an external power adapter (Part number: ITB20D3250, sold separately) that will enable the USB Hub to operate at full power. -
Mounting options
The USB Hub is thoughtfully designed for user convenience and adaptability. Equipped with integrated mounting brackets, installation is simplified. The hub can be mounted on a variety of surfaces such as walls or desks. The DIN rail bracket ensures secure mounting in industrial environments. -
High performance
The robust USB Hub supports USB SuperSpeed 3.2 Gen 1 (5 Gbps) and remains compatible with legacy peripherals. What's more, the USB Hub offers enhanced security thanks to the USB Event Monitor utility, a feature of the StarTech.com Connectivity Tools application. This utility records and time-stamps USB port usage, enabling IT administrators to identify potentially malicious devices.
- StarTech.com 4-Port Managed USB Hub with 4x USB-A, Heavy Duty with Metal Industrial Housing, ESD & Surge Protection, Wall/Desk/Din-Rail Mountable, USB 3.0/3.1/3.2 Gen 1 5Gbps - hub - 4 ports - TAA Compliant
- Hub - 4 ports
- Subtype
- USB
- Ports
- 3 x USB 3.2 Gen 2 + 1 x USB 3.2 Gen 1
- Surge protection, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), managed, fast charging support, CLI management, lockable ports
- USB 1.1, USB 2.0, USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1, Battery Charging 1.2
- 11.4 cm x 6.7 cm x 2.6 cm
- Black
- TAA Compliant
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop, DIN rail mountable, wall-mountable
- Subtype
- USB
- Ports
- Status Indicators
- Port status, power
- 3 x USB 3.2 Gen 2 Type A Battery Charging 1.2 , 1 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 Type B host , 1 x terminal block
- Black
- Included Accessories
- DIN-rail mounting kit, terminal block connector
- Cables Included
- 1 x USB-A to USB-B cable - 1.8 m
- MTBF
- 131,406 hours
- RoHS, WEEE, UASP (USB Attached SCSI Protocol)
- TAA Compliant
- 11.4 cm
- 6.7 cm
- 2.6 cm
- Shipping Width
- 21.3 cm
- Shipping Depth
- 14.9 cm
- Shipping Height
- 5.1 cm
- Shipping Weight
- 450 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 95% RH
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 75 °C
