This Privacy Screen for third-generation and newer 12.9 iPad Pro smoothly transitions from a clear view to an obscured screen beyond the intended viewing angle, significantly enhancing visual privacy in office or public environments. The anti-glare matte finish helps to reduce reflections in glare-prone environments and provides additional screen protection with a scratch and fingerprint-resistant coating.
4-Way Privacy and Touch Support
The security filter ensures optimal privacy in portrait or landscape orientations when viewed beyond 30° from the center, covering a total visible area of 60°. It supports touchscreen input and gestures, preserving the interactive experience of an iPad while maintaining the confidentiality of on-screen content. -
Installation
The screen protector is compatible with third-generation and newer 12.9 iPad Pro and features a precise fit that does not interfere with the display, camera, or speakers. The included installation kit and step-by-step instructions allow for a one-time application to the iPad screen. -
Blue Light Reduction
This Blue Light Reduction Privacy Shield reduces eye strain and improves visual comfort by blocking 40% - 51% of the blue light emitted from the display (in the 380nm - 480nm wavelength range). Symptoms of digital eye strain, such as headaches, dry eyes, and blurred vision, can be alleviated by using blue-light filtering privacy screens.
- StarTech.com - screen protector for tablet - for portrait/landscape, touch-enabled, +/-30° view, blocks up to 51% blue light, matte
- Product Type
- Screen protector - with privacy filter - 4-way
- Intended For
- Tablet
- Screen Size Compatibility
- 12.9"
- Protection
- Scratch-resistant, anti-glare, blue light reduction, fingerprint-resistant
- Package Content
- Screen protector, cleaning wipes, squeegee, dust remover, 2 guide stickers, wiping cloth
- Product Material
- Plastic
- 21.2 cm 27.7 cm
- Thickness
- 0.4 mm
- 58 g
- Black
- 2-year warranty
- Designed For
- Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation, 6th generation)
- Product Type
- Privacy Protection
- 4-way
- Intended For
- Tablet
- 12.9"
- Protection
- Package Content
- Product Material
- Plastic
- 21.2 cm
- 27.7 cm
- 58 g
- Thickness
- 0.4 mm
- Black
- Limited warranty - 2 years
- Shipping Width
- 39 cm
- Shipping Depth
- 0.6 cm
- Shipping Height
- 24.5 cm
- Shipping Weight
- 160 g
- Designed For
StarTech.com Desk Mountable Tablet Stand | In Stock | £106.84 |
StarTech.com Secure Tablet Stand w/Cable Lock, Locking 7.9-13"Tablet | In Stock | £90.64 |
