Share up to four USB 3.0 devices between four different computers. This 4x4 USB 3.0 peripheral sharing switch lets you share four USB 3.0 peripheral devices between four different computers, providing a cost-effective way to create a more productive, space-efficient work area.
Save the expense of purchasing duplicate peripherals, by sharing devices (such as USB printers, portable hard drives, mouse and keyboard) with up to four computers. The USB switch also lets you avoid having to swap cables from one system to another, saving time and effort.
Enjoy fast data transfers to and from your shared peripheral devices. The USB switch supports USB 3.0 (up to 5Gbps), providing high-bandwidth support for devices like external hard drives and webcams. The USB 3.0 switch is also backward compatible with USB 2.0/1.1 and works with older devices.
The plug-and-play USB switch is easy to use, with no drivers or software required. It features a remote port selector that lets you switch peripheral devices from one computer to another with the press of a button. The LED indicates the active computer.
The switch's compact design takes up minimal desk space and it's USB-powered.
The 4-port USB switch can also be connected to a USB hub or docking station, to expand the number of shared devices.
- StarTech.com USB 3.0 Peripheral Sharing Switch - 4 USB 3.0 x 4 Computers - Mac / Windows / Linux - USB A/B Switch - USB Switch (HBS304A24A) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 8 x SuperSpeed USB 3.0
- USB powered, plastic housing, over-current protection
- 9.4 cm x 9.4 cm x 2.6 cm
- 130 g
- Black
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB 3.0 Type A , 1 x USB 3.0 Type B , 1 x micro-USB (power only) Type B
- Black
- Cables Included
- 2 x USB-A to USB-B cable - 1.2 m , 2 x USB-A to USB-B cable - 1.8 cm , 1 x remote port selector - 1.8 cm
- 9.4 cm
- 9.4 cm
- 2.6 cm
- 130 g
- Shipping Weight
- 650 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Humidity Range Storage
- 0 - 80%
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £99.33 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £25.64 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £36.79 |
StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power | In Stock | £57.93 |
StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £11.11 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £8.94 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £10.90 |
StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £11.79 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.74 |
StarTech.com 2m 6ft USB 3.0 C to B Cable | In Stock | £15.16 |
StarTech.com 1m USB A to C Cable - USB 3.0 | In Stock | £11.23 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £17.80 |
StarTech.com 0.5m USB to USB-C Cable 10Gbps | In Stock | £10.20 |
