Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one USB Type-C port. The 4-port USB 3.0 hub lets you connect both USB-C and USB-A peripherals to your laptop or Chromebook, through a single USB Type-C or Thunderbolt 3 port.
The hub is ideal for virtually all USB-C equipped laptops, such as the Dell Latitude 11 5000 2-in-1, and the Dell XPS 12.
This USB 3.1 Gen 1 hub lets you expand your USB connection options using the USB-C port on your computer. It offers one USB-C and three USB-A ports, letting you connect traditional USB devices now, while still being able to connect the growing number of USB Type-C devices in the future.
The integrated, easy-to-use USB Type-C connector is small and reversible, which makes for easier insertions. You can connect the plug with either side facing up, which means less risk of damaging your ports, and less frustration.
With a compact and lightweight design, the USB-powered hub is tailored for mobility. It easily tucks into your carrying case and expands your connectivity when traveling.
Plus, this versatile USB hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
Avoid the nuisance and cost of purchasing new peripherals by using this USB 3.0 hub with your current USB 3.0 and 2.0 devices. The bus-powered hub installs in seconds with no additional drivers or software required, and it's compatible with virtually all operating systems.
- StarTech.com 4-Port USB 3.0 Hub - Powered USB 3.1 Gen 1 Hub - USB-C to 1x USB-C and 3x USB-A Adapter - USB-C Port Expander (HB30C3A1CFB) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB powered
- USB 3.0, USB 3.1
- 4 cm x 7.5 cm x 1.3 cm
- Black
- 2-year warranty
- Designed For
- P/N: 2SD4FCRU3C, CFASTRWU3C, FCREADU3C, MST30C2DPPD, S251BU31C3CB, SDMSDRWU3AC, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- USB 3.0, USB 3.1
- 3 x USB 3.0 Type A , 1 x USB 3.0 Type C
- Black
- FCC, RoHS
- 4 cm
- 7.5 cm
- 1.3 cm
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 0 - 90%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black | In Stock | £21.36 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White | In Stock | £21.33 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £23.49 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.55 |
StarTech.com USB 3.1 Tool-free Enclosure | In Stock | £25.00 |
StarTech.com USB-C to Gigabit Adapter | In Stock | £25.84 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £34.22 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.21 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £16.47 |
StarTech.com 7 Port Compact USB 3.0 Hub | In Stock | £48.51 |
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop | In Stock | £57.55 |
StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White | In Stock | £42.64 |
StarTech.com 4 Port USB 3.0 C Hub - C to A | In Stock | £32.28 |
StarTech.com 4 Port USB C Hub with PD 2.0 | In Stock | £37.95 |
StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 | In Stock | £51.70 |
StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £33.01 |
StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £44.99 |
StarTech.com 4 Port USB 3.0 C Hub - C to A | In Stock | £38.11 |
StarTech.com 4 Port USB C Hub - C to C & A | In Stock | £29.51 |
StarTech.com 4 Port USB 3.0 Hub A to C & A | In Stock | £45.64 |
StarTech.com 4 Port USB-C Hub - C to C & A | In Stock | £40.72 |
StarTech.com 7 Port USB-C Hub - C to C & A | In Stock | £78.39 |
StarTech.com 4-Port USB-C Hub - USB 3.1 | In Stock | £36.22 |
StarTech.com 4-Port USB 3.0 Hub with On/Off | In Stock | £26.33 |
StarTech.com 4 Port USB 3.0 Hub USB-C to 4x USB-A | In Stock | £31.37 |
StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C | In Stock | £29.32 |
StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable | In Stock | £47.36 |
StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable | In Stock | £27.93 |
StarTech.com 4-Port USB-C Hub, 100W PD | In Stock | £41.40 |
StarTech.com Portable 4pt USB-C Hub, 10Gbps | In Stock | £34.58 |
