Turn your laptop's USB Type-C port into four USB Type-A ports (5Gbps) using this bus-powered hub. This portable USB 3.0 hub expands your laptop or desktop connectivity by adding four USB Type-A ports through a single USB Type-C or Thunderbolt 3 port. And, because it's USB bus-powered, you don't need to connect an external power adapter, which makes travel more convenient and workstations less cluttered.
With its compact design, you can take this portable USB-C hub anywhere you go. It's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation.
Plus, the hub is bus powered, which means it draws power directly from the USB-C port on your computer. This makes it even more portable because there are fewer cables to carry with you when you travel and it doesn't need an external power adapter.
If you're looking to extend the life of your existing USB-A peripheral devices, then this hub is the perfect solution. By converting a single USB-C port into four USB-A ports, you can continue to use all of your existing USB 3.0 devices such as flash drives, external hard drives, and printers. Now you can save money by avoiding the added cost and hassle of purchasing new USB-C equipped peripherals.
This USB hub is multi-platform compatible, which means it will work with a wide range of laptops. It also works with a range of operating systems such as Windows, Mac, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
- StarTech.com 4 Port USB C Hub with 4x USB-A Ports (USB 3.0 SuperSpeed 5Gbps), USB Bus Powered, Portable/Laptop USB-C to USB-A Adapter Hub, USB 3.1 Gen 1/USB 3.2 Gen 1 Type-C Hub, White - Windows/macOS/Linux (HB30C4ABW) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB powered
- USB 1.1, USB 2.0, USB 3.0
- 4.1 cm x 8 cm x 1.5 cm
- 35.2 g
- White
- System Requirements
- Apple MacOS, Linux, Microsoft Windows, Google Chrome OS
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- Processor
- X VIA VL812
- 4 x USB 3.0 output Type A , 1 x USB 3.0 input Type C
- White
- Plug and Play, FCC, RoHS
- OS Required
- 4.1 cm
- 8 cm
- 1.5 cm
- 35.2 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 85% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 | In Stock | £23.45 |
StarTech.com Rugged Hard Drive Enclosure | In Stock | £35.75 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £33.93 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.21 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.87 |
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop | In Stock | £57.55 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.14 |
StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White | In Stock | £42.64 |
StarTech.com 4 Port USB 3.0 C Hub - C to A | In Stock | £32.28 |
StarTech.com 4 Port USB 3.0 C Hub - C to A | In Stock | £38.11 |
StarTech.com 4 Port USB C Hub - C to C & A | In Stock | £29.51 |
StarTech.com 7 Port USB-C Hub - C to C & A | In Stock | £78.39 |
StarTech.com 4-Port USB-C Hub - USB 3.1 | In Stock | £36.22 |
StarTech.com 4-Port USB 3.0 Hub with On/Off | In Stock | £26.37 |
StarTech.com 4-Port USB-C Hub, 100W PD | In Stock | £41.46 |
StarTech.com Portable 4pt USB-C Hub, 10Gbps | In Stock | £34.29 |
