Control 4 systems using a single peripheral set, with dual DVI console connections and multiple picture-in-picture display modes. The SV431DVIUAQV 4-Port DVI KVM Switch with Quad-View Display lets you control 4 systems using a single peripheral set, with dual DVI console connections and multiple picture-in-picture display modes.
The DVI USB KVM features an integrated 2-port USB 2.0 hub for connecting additional peripherals to share, plus StarTech.com has included the necessary DVI, USB and audio cables for a ready-to-use solution.
The Quad-View function integrates a quad screen splitter into the KVM switch to offer several picture-in picture display modes so you can monitor some or all of the connected PCs on the primary console display while interacting with the active PC on the secondary display. Choose from: Quad-View: Displays all 4 connected PCs simultaneously; Picture-and-Picture (PAP): Displays the active PC in the main display area and 3 others along the right side; Picture-in-Picture (PIP): Displays the active PC in the main display area and 1 other in a movable and sizeable PIP window; Full-View: Displays the active PC on both of the console displays.
The KVM switch integrates front, push-button controls for simple switching between PCs, choosing your desired display mode and accessing the KVM menu, plus hot-keys and RS-232 command support, for flexible control.
For added versatility, you can daisy-chain up to 8 SV431DVIUAQV units total, for control of up to 32 PCs using a single peripheral set.
- StarTech.com 4 Port DVI USB KVM Switch with Dual DVI Console and Quad View 4-in-1 Display - KVM Switch with Quad Screen Splitter (SV431DVIUAQV) - KVM / audio / USB switch - 4 ports - rack-mountable
- KVM / audio / USB switch - 4 ports - cascadable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- On-Screen Display, built-in 2-port USB 2.0 hub, Picture in Picture function, Picture and Picture function
- Power
- AC 120/230 V
- 43.8 cm x 20 cm x 4.4 cm
- 5.6 kg
- Black
- 2-year warranty
- Designed For
- P/N: SVA12M5NA
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Cascading Depth
- 8
- Max Resolution
- 1920 x 1200
- 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 2 x DVI-I , 1 x audio mini-jack , 4 x USB Type B , 4 x audio mini-jack , 4 x DVI-I , 2 x serial (RS-232) RJ-45 , 2 x USB 2.0 Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Cables Included
- 4 x DVI cable , 4 x USB cable , 4 x audio cable
- Rack Mounting Kit
- Included
- FCC, RoHS
- 43.8 cm
- 20 cm
- 4.4 cm
- 5.6 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
- P/N: SVA12M5NA
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £269.04 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £197.20 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £166.96 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.94 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £575.96 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £319.01 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £657.69 |
StarTech.com 2 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £349.21 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display | In Stock | £554.15 |
