StarTech.com 4 Bay USB 3.0 Hard Drive Dock
Quicklinx: 7W8SWS00 Mfr#: SATDOCK4U3
  • Windows 8 (32/64 bits)
Enable quick access to four 2.5"/3.5" SATA HDD over USB 3.0. The SATDOCK4U3 USB 3.0 4-Bay SATA Hard Drive Docking Station is a convenient, time-saving storage solution for 2.5-inch and 3.5-inch SATA hard drives (HDD) and solid state drives (SSD), that enables you to connect up to 4 SATA drives through a single host connection, while controlling the power status (on/off) of each individual drive independently from the rest.
The hard drive docking station features SuperSpeed USB 3.0 connectivity (backward compatible with USB 2.0), which supports data transfer rates up to 10x faster than USB 2.0. The docking station also offers dual built-in, variable-speed 60mm cooling fans with manual control (including off).
Double the value of this hard drive docking station, by using a SATA to IDE hard drive adapter (SAT2IDEADP), which enables you to use any 2.5 or 3.5in IDE hard drive in a SATA hard drive dock slot.
StarTech.com 4 Bay USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD - HDD docking station - SATA 3Gb/s - USB 3.0
HDD docking station - external
Bays
4
Bus Type
USB 3.0
Expansion Bays
4 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
Power indicator
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Product Material
Plastic
Power Source
Included AC adapter
Linux, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
17.3 cm x 29.1 cm x 9.5 cm
1.1 kg
Bays
4
2.5", 3.5"
Host Bus
USB 3.0
Product Material
Plastic
Power indicator
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Bays
1 x SATA 3Gb/s - SATA power , 4 x SATA 3Gb/s - SATA
1 x USB 3.0 - 9 pin USB Type A
Power supply
1 x USB cable - external
Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
Plug and Play, FCC, RoHS
Power Source
Included AC adapter
Power adapter
17.3 cm
29.1 cm
9.5 cm
1.1 kg
5 °C
80 °C
8 - 90%
