StarTech.com 3m 10 ft Premium High Speed HDMI Cable with Gripping Connect
Quicklinx: G8L0WS00 Mfr#: HDMM3MLP
Length: 3m
15 In Stock
£16.75 ex VAT
£20.10 inc VAT
HDMI 2.0 Cable Gripping Connectors 4K 60Hz Lifetime Warranty. This 3-meter HDMI cable has been tested in accordance with the Premium HDMI Cable Certification Program. This ensures it's able to deliver the newest technical features that the latest HDMI specifications have to offer, including enhanced resolutions and protection against EMI interference.
The cable features high-retention HDMI connectors that fasten firmly inside each port. This helps to prevent accidental disconnections and signal loss.
Each cable is labeled with the Premium HDMI Cable authentication, so you can be confident that you are purchasing a high-quality premium cable with guaranteed performance.
Experience the latest that HDMI has to offer
The cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors.
With higher resolutions, increased speeds, and sharper images, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI capabilities available today. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage.
Plus, the cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
Secure your connections and avoid signal loss
The gripping HDMI connectors are ideal for high traffic applications or in environments where vibrations could cause accidental disconnects and picture loss. It works great with wall-mounted equipment and in situations where equipment is frequently moved.
Plug the connectors inside the HDMI ports and the connectors will automatically latch to the inside of the port, there are no special screws or accessories required. The grips will create contact pressure inside the port and ensure that the connectors don't loosen over time.
Provide superior connections with Premium HDMI certification
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center to ensure it supports the high-bandwidth enabled features it promises. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
The HDMM3MLP is backed by StarTech.com's Lifetime Warranty.
  • Experience the latest that HDMI has to offer
    The cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors. With higher resolutions, increased speeds, and sharper images, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI capabilities available today. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage. Plus, the cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
  • Secure your connections and avoid signal loss
    The gripping HDMI connectors are ideal for high traffic applications or in environments where vibrations could cause accidental disconnects and picture loss. It works great with wall-mounted equipment and in situations where equipment is frequently moved. Plug the connectors inside the HDMI ports and the connectors will automatically latch to the inside of the port, there are no special screws or accessories required. The grips will create contact pressure inside the port and ensure that the connectors don't loosen over time.
  • Provide superior connections with Premium HDMI certification
    The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center to ensure it supports the high-bandwidth enabled features it promises. An EMI test is also performed to ensure the cable minimizes interference with wireless signals. The HDMM3MLP is backed by StarTech.com's Lifetime Warranty.
StarTech.com 10ft (3m) HDMI 2.0 Cable with Gripping Connectors, 4K 60Hz Premium Certified High Speed HDMI Cable with Ethernet, HDR10, 18Gbps, HDMI Video Cord for Monitor/TV, M/M, Black - Ultra HD HDMI Cord - HDMI cable - 3 m
Cable
High Speed - HDMI cable
Max Output Resolution
3840 x 2160 - 60 Hz
Length
3 m
Connector
HDMI - male - straight
Connector (Second End)
Audio Return Channel (ARC), 4K format support, 3D ready, colourimetry BT.2020 support, HDR 10 support, 32 audio channels, gripping connectors, 1536 kHz audio sampling rate
Cable Type
Jacket Material
PVC
Shielding Material
Length
3 m
Plated Connector
Gold
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connector
19 pin HDMI Type A - male - straight
RoHS, WEEE
2 cm
1.05 cm
232 g
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
2.1 cm
Shipping Weight
244 g
Limited warranty - lifetime
Length: 3m
