StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI
Quicklinx: GGR4WS00 Mfr#: HDMM21V1M
Length: 1m
29 In Stock
£15.88 ex VAT
£19.05 inc VAT
This 3.3 ft. (1 m) Ultra High Speed HDMI 2.1 Certified Cable withstands the daily demands of connecting your HDMI devices. Tested to endure strenuous wear and tear, this durable cable is a must-have for both business and consumer applications.
This high performance 8K cable supports resolutions of up to 8K at 60Hz (7680x4620p), 5K at 60Hz, 4K at 120Hz and bandwidths of up to 48Gbps. It also supports HDR10+ (High Dynamic Range) and Dolby Vision for higher contrast ratio and vivid colors.
Plus, eARC (Enhanced Audio Return Channel) has up to 32 uncompressed 5.1 and 7.1 digital audio channels to support DTS-HD Master Audio, DTS: X, Dolby TrueHD, Dolby Atmos for high quality sound. Latest HDCP 2.3 encrypts and secures your video and audio content.
With higher resolutions, increased speeds, sharper images, and crystal-clear audio, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI 8K performance available today. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage.
This cable works with all 8K ready devices and is also backward compatible with previous HDMI specifications.
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center to ensure it supports the high bandwidth enabled features it promises. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
StarTech.com 3ft (1m) HDMI 2.1 Cable, Certified Ultra High Speed HDMI Cable 48Gbps, 8K 60Hz/4K 120Hz HDR10+ eARC, Ultra HD 8K HDMI Cable / Cord w/TPE Jacket, For UHD Monitor/TV/Display - Dolby Vision/Atmos, DTS-HD (HDMM21V1M) - HDMI cable with Ethernet - 1 m
Cable
Ultra High Speed - HDMI cable with Ethernet
Double shielded
American Wire Gauge (AWG)
30/32
Max Output Resolution
7680 x 4620 - 60 Hz
Length
1 m
Grey, black
Connector
HDMI - male
Connector (Second End)
HDMI - male
Passive cable, 4K120Hz support, 8K60Hz support
P/N: 4PORT-8K-HDMI-SWITCH
Cable Type
Ultra High Speed - HDMI cable with Ethernet passive, 4K120Hz support, 8K60Hz support
Double shielded
30/32
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
1 m
Plated Connector
Gold
Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Atmos support, Enhanced Audio Return Channel (eARC), Dolby DTS 5.1 support, Dolby DTS:X support, Dolby Vision, 48Gbps support, Dolby DTS 7.1 support, support HDR10+, strain relief, 32 audio channels, EMI/RFI protection, outer diameter 6mm
Grey, black
Adapters & Converters
7680 x 4620
Refresh Rate
60 Hz
Connector
19 pin HDMI Type A - male
RoHS, HDCP 2.3
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
3 cm
Shipping Weight
88 g
Limited warranty - lifetime
GGR4 StarTech.com 12ft Ultra High Speed HDMI 2.1 In Stock £33.33
GGR4 StarTech.com 20in Ultra High Speed HDMI 2.1 In Stock £16.34
Length: 1m
