StarTech.com 32in. Monitor Privacy Screen - Universal - Matte / Glossy
Quicklinx: G8L3WS00 Mfr#: PRIVSCNMON32
Accessory Type: Privacy Screen
22 In Stock
£116.94 ex VAT
£140.32 inc VAT
Confidentiality Screen Filter - 16:9 Aspect Ratio - Matte or Glossy - 2-Year Warranty
The monitor privacy screen is easy to attach and remove. Simply attach the 32 inch privacy screen to your 16:9 aspect ratio display using the attachment strips or slide-mount tabs. This confidentiality screen filter is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Protect Your Privacy
The privacy screen protector for desktop monitors is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. You can have a peace of mind while working in the office or public environments because you know your screen is protected with the 30+/- degree privacy viewing angle. The cutout on the top corner of the privacy screen makes it easy to remove for sharing content with trusted audiences or switching between finishes.
Blue Light Reduction
With working from home becoming more prominent and screen time on the rise, reducing blue light exposure is important. The monitor privacy film is designed to filter blue light (390nm~480 wavelength) and reduce digital eye strain.
Antimicrobial Protection
Our privacy screens feature an anti-microbial coating on the matte-side of the filter. Embedded antimicrobial technology provides protection against bacterial microbes by continuously eliminating up to 99.99% of certain surface bacteria. Antimicrobial screen protectors are ideal for environments where disinfection is important.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The TAA compliant PRIVSCNMON32 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Protect Your Privacy
  • Blue Light Reduction
    Lowering blue light exposure is important. To reduce digital eye strain, the monitor privacy film blocks between 40% to 51% of the blue light in the wavelength range of 380nm to 480nm.
  • Antimicrobial Protection
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The TAA compliant PRIVSCNMON32 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Monitor Privacy Screen for 32 inch Display, Widescreen Computer Monitor Security Filter, Blue Light Reducing Screen Protector (PRIVSCNMON32) - display privacy filter - 32" wide
Display privacy filter
Package Content
Adhesive strips, slide mount tabs
Transparent
Display Screen Size Compatibility
32" wide
Product Material
Plastic
70.8 cm x 39.8 cm x 0.05 cm
125 g
Package Content
32" wide
Product Material
Plastic
70.8 cm - 39.8 cm - 0.05 cm
125 g
87.1 cm x 47.3 cm x 0.3 cm / 613 g
Transparent
Display Filter
Aspect Ratio
16:9
Mounting Kit
Included
Anti-glare, matte, glossy surface, +/- 30° visible angle, blue light reduction
RoHS, REACH
G8L3 StarTech.com 34in. Monitor Privacy Screen - Ultrawide - Matte / Glossy In Stock £123.08
G8L3 StarTech.com 17" Monitor Privacy Filter In Stock £41.67
G8L3 StarTech.com 19" Monitor Privacy Filter In Stock £45.21
G8L3 StarTech.com 19.5" Monitor Privacy Filter In Stock £46.05
G8L3 StarTech.com 22" Monitor Privacy Filter In Stock £53.06
G8L3 StarTech.com 23.6" Monitor Privacy Filter In Stock £56.67
G8L3 StarTech.com 28" Monitor Privacy Filter In Stock £79.74
G8L3 StarTech.com 23.8-inch Gold Privacy Screen In Stock £63.76
G8L3 StarTech.com 24-inch Gold Privacy Screen In Stock £67.46
G8L3 StarTech.com 24-inch Gold Privacy Screen In Stock £65.19
G8L3 StarTech.com 27-inch Gold Privacy Screen In Stock £84.14
