Organize and manage network, server and KVM cabling in your server rack. The CABLMANAGER3 30U Vertical Server Rack Cable Manager with Hinged Cover can be mounted to a 2 or 4 post rack to provide efficient cable organization.
Featuring a high-capacity cable channel and a hinged door that provides easy access for the addition or removal of cables, this server rack cable management panel offers rear and side pass-through holes for easy cable routing to all of your rack mounted devices.
The vertical cable organizer is a durable solution for server room and structured wiring closet applications, perfect for routing patch panel and other rackmount equipment wiring in an orderly fashion.
- StarTech.com 30U Vertical Server Rack Cable Manager with Hinged Cover - cable management rack - 30U
- Product Type
- Cable management rack
- Package Content
- Washer, 8 M8 screws, 8 nuts
- Black
- Height (Rack Units)
- 30U
- Product Material
- Steel
- 13 cm x 16 cm x 135 cm
- 7.3 kg
- Limited lifetime warranty
- Designed For
- P/N: RK4242BK
- Product Type
- Product Material
- Steel
- Package Content
- 30U
- 13 cm
- 16 cm
- 135 cm
- 7.3 kg
- Black
- Limited warranty: - lifetime
- Designed For
- P/N: RK4242BK
