StarTech.com 30 ft Cat5e Red Snagless RJ45 UTP Cat 5e Patch Cable
Quicklinx: 6LCCWS00 Mfr#: 45PATCH30RD
StarTech.com's Cat5e UTP Snagless Patch Cables offer reliable Ethernet connections. This 30 ft cable meets or exceeds all Category 5e specifications and features a durable red jacket that simplifies departmental color coding while providing rugged flexibility for network connections.
To ensure long-lasting performance, StarTech.com's high quality Cat5e UTP Snagless Patch Cables feature a snagless design that protects the RJ45 clip from damage and makes the cables less prone to snagging during installation. The cables also feature PVC molded strain relief that prevents the RJ45 connector termination point from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
StarTech.com's 30 ft Red Cat5e UTP Snagless Patch Cable is constructed of only top quality materials to ensure optimum durability.
StarTech.com Cat5e Ethernet Cable - 30 ft - Red- Patch Cable - Snagless Cat5e Cable - Long Network Cable - Ethernet Cord - Cat 5e Cable - 30ft (45PATCH30RD) - patch cable - 9.1 m - red
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless
Length
9.1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
1-year warranty
P/N: USB31000NDS, USB31000S, USB31000SW
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
28
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded, snagless
Length
9.1 m
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
1-year warranty
6LCC StarTech.com 19in Cable Management Panel In Stock £24.78
