Only best-quality components are used when StarTech.com's expert manufacturing team creates its cabling and this cable is not different. The 30-inch MPC2 CD-ROM audio cable will let you connect a CD-ROM audio output to a sound card. Cables help StarTech.com maintain its tradition of offering top-notch parts and products for the best price possible.
- StarTech.com 30in MPC2 CD-ROM Audio Cable - F/F - audio cable - 76.2 cm
- Audio cable
- Length
- 76.2 cm
- Connector
- MPC - female
- Connector (Second End)
- MPC - female
- Limited lifetime warranty
- Designed For
- P/N: PCISOUND4CH, PEXSOUND7CH
- Audio cable
- Length
- 76.2 cm
- Connector
- 4 pin MPC - female
- Designed For
