This USB Hub adds three USB-A 3.2 Gen 1 (5Gbps) ports and one Gigabit Ethernet port to a USB-C enabled desktop or laptop computer. The USB Hub connects to a USB-C port on a computer, using the built-in 1ft. (30cm) host cable. The USB hub is backward compatible with USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB peripherals (e.g., thumb drives, external HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets).The USB hub is compact in size, facilitating portability when travelling.
Gigabit Ethernet
The USB hub features a Gigabit Ethernet adapter. The Ethernet controller is compatible with the IEEE 802.3u/ab standards and supports Wake-on-LAN (WoL), Jumbo Frames, and V-LAN Tagging. The network adapter enhances laptop network reliability, security, and performance by utilizing wired 10/100/1000Mbps Ethernet. -
Bus-Powered with Optional Auxiliary Power
The USB hub can operate with bus power alone, but features a Micro USB power input that can be connected to a USB power adapter (not included), providing up to 4.5W (5V/0.9A) of power in addition to the up to 15W of bus power from the USB host. This flexibility is ideal for applications where additional power may be required, such as connecting a high-powered USB device, like an external SSD/HDD, while using the other ports to connect lower powered devices. For added protection, the USB hub features Overcurrent Protection (OCP). OCP prevents faulty USB peripherals from drawing more power than is safely allocated. -
Plug and Play
This device supports all major operating systems, including Windows, macOS, ChromeOS, iPadOS, and Android. The Hub is automatically detected, configured, and installed upon connection to a host computer, such as Apple MacBook, Lenovo X1 Carbon, and Dell XPS. The extra-long built-in 1ft. (30 cm) USB-A host cable enables quick and convenient setup and reduces connector strain on 2-in-1 devices, such as the Surface Pro 7, iPad Pro, and laptops on riser stands. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The software suite includes: •Text | MAC Address Pass-Through Utility : Improve network security. •Text | USB Event Monitoring Utility : Track and log connected USB devices. •Text | Wi-Fi Auto Switch Utility : Enable users to quickly access faster network speeds via wired LAN.
- StarTech.com 3-Port USB-C Hub with Ethernet, 3x USB-A Ports, Gigabit Ethernet, USB 3.0 5Gbps, Bus-Powered, USB Type-C Hub w/GbE and 1ft/30cm Long Cable, Portable Laptop USB C Hub Adapter - USB Expansion Hub, RJ45 (5G3AGBB-USB-C-HUB) - hub - 3 ports
- Hub - 3 ports
- Subtype
- USB
- Ports
- 3 x USB 3.2 Gen 1 + 1 x micro-USB + 1 x 10/100/1000
- Performance
- Data transfer rate: up to 5 Gbps , Throughput (full duplex): up to 2 Gbps
- Jumbo Frame Support
- 9KB
- Flow control, WOL, full duplex mode, USB powered, plastic housing, priority encoding, USB overcurrent detection and prevention, EEE, VLAN Tagging, Auto MDIX
- IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az, USB 3.2 Gen 1
- 5.4 cm x 42 cm x 1.6 cm
- 82 g
- Space grey
- System Requirements
- Android, Google Chrome OS, Apple iPadOS, Apple macOS 10.12 - 10.15, Apple macOS 10.11, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Linux Kernel 4.11.x or later (LTS versions only), Apple macOS 13.0
- 2-year warranty
- Hub - 3 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Performance
- 9KB
- Processor
- X ASIX / VIA VL817 / AX88179A
- Status Indicators
- Link/activity
- 3 x USB 3.2 Gen 1 Type A , 1 x 1000Base-T RJ-45 , 1 x micro-USB input Type B
- Space grey
- Cables Included
- 1 x USB-C cable - 30 cm
- Plug and Play, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
- OS Required
- 5.4 cm
- 42 cm
- 1.6 cm
- 82 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 138 g
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 70 °C
- 0 - 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 80 °C
StarTech.com 3-Port USB-C Hub w/Gb Ethernet | In Stock | £42.63 |
StarTech.com 4-Port USB Hub 5Gbps, Portable | In Stock | £29.26 |
StarTech.com 4-Port USB-C Hub, 5Gbps | In Stock | £31.41 |
