StarTech.com 3-Port USB-C Hub, 2.5GbE, PD
Quicklinx: HKKBWS00 Mfr#: 10G2A1C25EPD-USB-HUB
Type: [N/A]
Interface: USB
Speed: [N/A]
Ports: 5
Form Factor: [N/A]
20 In Stock
£64.03 ex VAT
£76.83 inc VAT
This USB Type-C Hub with 2.5Gigabit Ethernet and 100W USB Power Delivery Pass-Through adds three USB 3.2 Gen 2 (10Gbps) ports (2x USB-A, 1x USB-C) to a USB-C enabled computer. Connect the USB hub to a USB-C port on a laptop, using the built-in 1ft (30cm) USB-C host cable. Charge a host laptop by connecting the host laptop's USB-C power supply to the USB Power Delivery (PD) 3.0 port. Backward compatibility with USB 2.0 (480Mbps) devices ensures support for a wide range of modern and legacy USB peripherals.
  • 2.5 Gigabit Ethernet
    The USB hub features a 2.5 Gigabit Ethernet adapter. The Ethernet controller is compatible with the IEEE 802.3bz standard (2.5GBASE-T/NBASE-T) and supports Wake-on-LAN (WoL), Jumbo Frames, and V-LAN Tagging. The network adapter enhances network reliability, security, and performance at speeds of up to 10/100/1000/2500Mbps.
  • USB Power Delivery Pass-Through
    This USB hub features 100W USB Power Delivery 3.0 pass-through (85W laptop charging). Connect a power source to the PD pass-through port to power the connected host device. PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when switching power sources (USB-C power adapter to bus power). This Power is dynamically shared across the downstream ports. For added protection to the USB hub and any connected devices, the USB hub features Overcurrent Protection (OCP). OCP prevents faulty USB peripherals from drawing more power than is safely allocated.
  • Plug and Play
    This device is compatible with all major operating systems, including Windows, macOS, ChromeOS, iPadOS, and Android. The Hub is automatically detected, configured, and installed upon connection to a host computer.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | USB Event Monitoring Utility: Track and log connected USB devices. •Text | MAC Address Pass-Through Utility: Improve network security. •Text | Wi-Fi Auto Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
StarTech.com 3-Port USB-C Hub with 2.5 Gigabit Ethernet and 100W Power Delivery Passthrough Laptop Charging, USB-C to 2x USB-A/1x USB-C, USB 3.2 10Gbps Type-C Adapter Hub - Windows/macOS/Linux/Chromebook (10G2A1C25EPD-USB-HUB) - hub - compact - 3 ports
Hub - 3 ports
Subtype
USB
Ports
1 x USB-C + 3 x USB 3.1 + 1 x 2.5GBase-T
Jumbo Frame Support
USB powered, USB overcurrent detection and prevention, USB Power Delivery (up to 100 watt)
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, Power Delivery 3.0, USB 3.2 Gen 2
16.3 cm x 3.4 cm x 1.5 cm
68 g
Space grey
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Jumbo Frame Support
X Realtek Semiconductor RTL8156B
Status Indicators
Network
1 x USB 3.2 Gen 2 output (power delivery 3.0) Type C , 2 x USB 3.2 Gen 2 Type A , 1 x USB-C (Power Delivery 3.0) input Type C max 100W pass-through charging , 1 x 2.5GBase-T RJ-45
Space grey
1 x USB-C cable - 30.5 cm
MTBF
286,501.33 hours
Plug and Play, RoHS, USB Power Delivery 3.0
16.3 cm
3.4 cm
1.5 cm
68 g
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
129 g
10 - 85% RH
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Type: [N/A]
Interface: USB
Speed: [N/A]
Ports: 5
Form Factor: [N/A]
